Cylinder head testing - Part 1 - 823 whp base line on HTA88
Old Apr 10, 2009 | 02:43 PM
  #271
justa4banger's Avatar
one day i will have enough money to buy a built bushur 2.0
Old Apr 20, 2009 | 07:09 PM
  #272
X_Evo's Avatar
Did I miss something here? Where are the results of this test?
Old Apr 20, 2009 | 07:40 PM
  #273
xspsi4's Avatar
hope those Groden rods can survive being re torqued.
I cringe at the thought of it.
Old Apr 20, 2009 | 08:24 PM
  #274
DynoFlash's Avatar
Would you suggest I toss them ?
I am open to suggestions
Al
Old Apr 20, 2009 | 08:32 PM
  #275
sparky's Avatar
Toss them my way when you come back down to El Salvador, Al.
Old Apr 20, 2009 | 08:38 PM
  #276
xspsi4's Avatar
Al
I dunno, What does Buschur say? I just have seen this problem over and over again.
I think R&R makes a good set of rods that does not seem to have this problem.
Last I know people were trying to helicoil the threads in order to get them to hold better.
Old May 11, 2009 | 06:20 AM
  #277
X_Evo's Avatar
Any updates on this test?
Old Jun 12, 2009 | 10:52 AM
  #278
DynoFlash's Avatar
Well its been a while. I have been so busy with customer projects and my own STI which has taken huge amounts of time.
Lets bring you up to speed.
Thanks to David Buschur for supplying the amazing new spec Buschur piston by JE which is simply a work of art. Master Lego here at Dyno Flash expertly installed the new stock bore pistons into the block and last evening we proceeded to start to do some base line tuning and break in on the dyno.
Here is a video we made of the process
http://www.youtube.com/watch?v=cRbmDOu-qfE
At the conclusion of the tuning session - after the cops shut us down re: a noise complaint - we noticed that the HKS cam gear had slipped on the intake side and the cam timing was off 6 degrees. As soon as I have a chance, I am going to get that set back to zero and tightend up and see what effect that chance has - if any on the dyno sheet.
Al
Old Jun 12, 2009 | 02:36 PM
  #279
MOREPSiTEHBETT4's Avatar
wow..buschur's motor is impeccable. Kudos to you AL on all the good work
Old Jun 12, 2009 | 09:41 PM
  #280
DynoFlash's Avatar
Yes, indeed, Buschur is the best 4G63 motor on earth.
Old Jun 13, 2009 | 08:16 AM
  #281
jimib's Avatar
Good work Al! Do you use loctite on the cam gears I used blue on mine, but have never seen a reccomended tq spec for them. I have been super courious about that spec.
Old Jun 13, 2009 | 08:26 AM
  #282
DynoFlash's Avatar
The cam gear was off; the dyno break was dragging and I had my heavy and very wide and (still slipping and spinning) street wheels
Later today I am going to redyno with the normal race wheels I did the base line on - and with the dyno break re-adjusted
Al
Old Jun 13, 2009 | 10:34 AM
  #283
evovin's Avatar
Al who coated your exhaust manifold?
Old Jun 14, 2009 | 10:06 AM
  #284
DynoFlash's Avatar
Buschur did it
DynoFlash
Evo X Dyno Results
17
Mar 1, 2009 07:09 AM
DynoFlash
136
Oct 12, 2008 02:47 PM
DynoFlash
41
Apr 25, 2008 07:32 AM
DynoFlash
171
Sep 1, 2007 03:16 AM
