Evo 8 turbo problems please help
Old Mar 17, 2009 | 06:59 PM
blk03evolution8's Avatar
Alright i have an evo 8 and at around 4 thousand rpm it loses all its juice and the turbo pretty much stops working i took it to the dealer and they told me it was only running 7 psi and i had no major turbo leaks! and that my turbo is bad or waste gate dont shut all the way what do you guys think? would appreciate the feedback thanks!
Old Mar 17, 2009 | 07:34 PM
sparky's Avatar
Do you have a boost gauge installed on your Evo?
Old Mar 17, 2009 | 07:38 PM
no just the stock one
Old Mar 17, 2009 | 08:09 PM
ktk's Avatar
ktk
so u have a boost gauge? I didn't think they had a stock boost gauge in the 8's
Old Mar 17, 2009 | 08:15 PM
well it has the gauge with the bars that goes up to like 1.3 or something u know what im talking about?
Old Mar 17, 2009 | 08:25 PM
whoang40's Avatar
Do you have 1 or 3 gauges in a row like the '05MR gauges that have a small mits. sign between them? I suggest pulling out your intake and checking your turbo for any play. Do you have a MBC anywhere, what are your mods? That would definitely help us diagnose the problem.
Old Mar 17, 2009 | 10:27 PM
sparky's Avatar
.... i took it to the dealer and they told me it was only running 7 psi and i had no major turbo leaks! and that my turbo is bad or waste gate dont shut all the way.....
Dealer couldn't pinpoint your problem, huh? That sounds typical. We'll try to help you figure it out, or if we can't, then we'll take a match to it.
Old Mar 18, 2009 | 05:27 AM
the only mods i have is an intake and hks ssq bov! also i got the three gauges in a row with the small mits symbols
Old Mar 18, 2009 | 05:41 AM
does this sound like a bad turbo becuase it spools up fine at first untill it hits 4000rpm then pretty much loses all its power?
Old Mar 18, 2009 | 05:46 AM
RockmanX's Avatar
take off your intake please and check for shaft play in the turbo wheel. Make sure it does not rattle and feel extremely loose. Move up and down back and forward should not be loose. Nice and firm it should be. That hks bov is junk by the way might want to look into something else.
Old Mar 18, 2009 | 07:39 AM
DDATuned's Avatar
I got a evo 8 turbo for sale. 120 shipped if you need
Old Mar 18, 2009 | 07:46 AM
ktk's Avatar
ktk
Yea that sounds like a boost gauge. If your car is stock you should be seeing a peak boost in the 19-17psi range with an Evo 8. I would probably reccomend checking for shaft play on the turbo though, pull of the intake and check it out. You're turbo might be broken
Old Mar 18, 2009 | 07:54 AM
Alright thanks guys ill check it out ant let you know what happens
Old Mar 18, 2009 | 08:31 AM
Ev0ikon's Avatar
No one mentioned leak test?!
Old Mar 18, 2009 | 08:37 AM
reef_420's Avatar
Take a look at your HKS, did you buy it used? maybe the piston is stuck open not letting you build boost?
