Having trouble finding.....
Old Mar 22, 2009 | 03:12 AM
Wick3d3vo9's Avatar
A small radiator fan, I have seen a few out there but I have only seen universal fan kits. Is the any small radiator fans out there strictly for the evo?? Also do the smaller fans work better or no?? I hoping to find one to replace the on that almost touches the stock ICP black hose.
Old Mar 22, 2009 | 07:28 AM
sparky's Avatar
Is it the stationary fan shroud almost touching the IC hose? Or do the rotating fan blades almost touch it? To answer your question, there are slimline fan kits for the Evo available from the vendors. Do you have the stock radiator?
Old Mar 22, 2009 | 08:53 AM
Ph3n1x's Avatar
I took a dremel and trimmed the edges off the fan blades. Or just get a universal fan. Both are simple to do.
Old Mar 22, 2009 | 01:16 PM
Wick3d3vo9's Avatar
Kinda both, I also just have heard it makes it easier to work on things with a slim fan. And yes I do have a stock radiator, would you recommend any vendors??
Old Mar 23, 2009 | 12:08 AM
Wick3d3vo9's Avatar
I've found a few fans but none seem to be what I"m looking for. Anyone running a slim fan on here that can chime in a help??
Old Mar 23, 2009 | 07:26 AM
JakeTheVIII's Avatar
There's no such thing as a radiator fan strictly for an evo, besides the stock one. You really can't find a small enough fan? Call ETS. I got a koyo radiator from them with slimfan, it's like 10", smallest I've seen/used. Works great.
Old Mar 23, 2009 | 07:30 AM
mugen777's Avatar
I did the same heres a pic for ya.... Just bought a 12" slim fan off of ebay for like 20 or 30 bucks, used the dremel and made it work. I had to dremel around the turbo housing as well so it wasn't touching.
Old Mar 23, 2009 | 11:50 AM
Wick3d3vo9's Avatar
So are yall just buying the fan or are you buying the whole piece that connects to the radiator?
Old Mar 23, 2009 | 01:45 PM
Ev0ikon's Avatar
Great idea! Don't mind if I borrow it? :P
Old Mar 23, 2009 | 01:52 PM
Don evo5's Avatar
Spal make a great slimline in 12" have one on my car with a koyo very easy install too
Old Jul 5, 2009 | 01:01 AM
Jp7's Avatar
Jp7
Bump for fan designed plug & play for Evo IX that will work with ETS Turbo Kits & have no clearance problem....
420a-t
Feb 23, 2015 07:19 AM
utggevox
Jun 10, 2012 04:30 PM
yellowevo82
Aug 16, 2010 11:49 AM
keith sedlak
Jun 21, 2010 04:57 AM
ralliartN20
Jun 7, 2008 06:34 PM
