Gear Synchros - Evo III
Old Mar 25, 2009 | 04:35 PM
EvoIIIAj's Avatar
Can anyone help me out? I'm looking at all of the OEM parts for an Evo III here:
http://www.dentsport.com/gallery/v/d.../evoparts_001/
Where it says; "Synchro ring" a couple of times, how do I know which synchro it is? or which gear its for? or does the same one work for all gears?
Is this the actual 3rd gear itself? "MD747250 3rd gear"
Better yet.
I want to replace the 3rd, 4th & 5th gear in my Evo III box.
So if anyone can tell me which part numbers I would have to get from that list I would appreciate it....
Old Mar 25, 2009 | 07:27 PM
Bimmubishi's Avatar
Third gear-
MD747250
Fourth Gear-
MD747255
Fifth Gear
MD745892
That's my shop's website above.
Old Mar 25, 2009 | 07:55 PM
EvoIIIAj's Avatar
Thanks for that.
One more question.
If my gears are gritting now, will buying those 3 part numbers solve it?
Old Mar 26, 2009 | 05:20 PM
EvoIIIAj's Avatar
Bump.
Old Mar 27, 2009 | 10:19 AM
94AWDcoupe's Avatar
Originally Posted by Bimmubishi
Third gear-
MD747250
Fourth Gear-
MD747255
Fifth Gear
MD745892
I think 747255 is the syncro for 3/4 gears.
747376 is number i have for 4th gear.
Old Mar 27, 2009 | 10:23 AM
94AWDcoupe's Avatar
Originally Posted by EvoIIIAj
Thanks for that.
One more question.
generally the gears themselves are not the problem. main causes of grinding
1.worn syncros
2. rounded slider teeth (from bad syncros or clutch)
3. worn shift forks from resting hand on shifter while in gear
Old Mar 27, 2009 | 10:25 AM
94AWDcoupe's Avatar
MD745892 is not 5th gear either. its a syncro part number
Old Mar 27, 2009 | 06:31 PM
EvoIIIAj's Avatar
Hmmm I see.
Do you know anyone I could ask to get the part numbers to change my 3rd/4th/5th gear synchros?
Old Mar 27, 2009 | 07:49 PM
Bimmubishi's Avatar
They are all syncro numbers. They are supposed to be. I just skipped the explanation and went right for the actual problem.
Sorry.
Old Mar 27, 2009 | 07:57 PM
Bimmubishi's Avatar
PS- you should inspect the bearings also. If they have excessive wear the teeth can loose meshing tolerance (for lack of better english) and then break teeth. They're probably fine and you'll be well served doing the syncros but you should at least inspect the bearings while the transmission is apart.
Alex
Old Mar 27, 2009 | 08:11 PM
runuts's Avatar
OK, here's part numbers for ya. If you need any other evo 3 part numbers, let me know.
MD746442 - 1st/2nd Hub & Sleeve
MD747378 - 3rd/4th Hub & Sleeve
MD746446 - 5th Gear Hub/Sleeve
MD745477 - 1st Gear Synchro
MD746435 - 2nd Gear Synchro - (Double Synchro)
MD747255 - 3rd Gear Synchro - (Double Synchro)
MD747255 - 4th Gear Synchro - (Double Synchro)
MD745892 - 5th Gear Synchro
MD743979 - 1st Gear
MD746691 - 2nd Gear
MD747250 - 3rd Gear
MD747252 - 4th Gear
MD743980 - 5th Gear - (Input Shaft)
MD743319 - 5th Gear - (Intermediate Shaft)
Old Mar 27, 2009 | 08:23 PM
94AWDcoupe's Avatar
runuts,
thanks for posting those numbers
can I get ?
input shaft
intermediate shaft
1/2 fork
3/4 fork
Old Mar 27, 2009 | 08:29 PM
runuts's Avatar
Here ya go
MD747887 - Input Shaft
MD748830 - Intermediate Shaft
MD735035 - 1/2 Fork
MD735036 - 3/4 Fork
Old Mar 27, 2009 | 11:41 PM
EvoIIIAj's Avatar
Are those synchro's for the GSR gearbox?
Old Mar 28, 2009 | 06:43 AM
EvoIIIAj's Avatar
runuts-
Can you identify the 2nd/3rd/4th/5th synchros from these pics? My supplier told me to tell him which ones they are.
