Fp Red, 30R or 35R?
Old Mar 27, 2009 | 11:38 PM
Cyp's Avatar
Cyp
Originally Posted by Mellon Tuning
I say do the 35R, it'll give you ~ 500awhp now and more later with additional mods
that would be one quick grocery grabber for me!
Old Mar 28, 2009 | 12:20 PM
bnice01's Avatar
going off fp stats the hta 30r has the same flow rate as the fpred but comes in a bigger compressor housing.
I have a gt3071 and making around 480 DLL numbers on meth.
Old Mar 28, 2009 | 12:36 PM
idriveanevo's Avatar
i would say go with the 35r... its just more room for improvement
Old Mar 28, 2009 | 12:53 PM
jamevo8's Avatar
I have a HTA3076r and love it! theres no lag what so ever
Old Mar 28, 2009 | 01:03 PM
projectevo9's Avatar
RedZilla all day
Old Mar 28, 2009 | 01:24 PM
gsrboi80's Avatar
35R
Old Mar 28, 2009 | 01:34 PM
EvoChrisLee's Avatar
+ 1 35r
Old Mar 28, 2009 | 01:57 PM
Most-Wanted's Avatar
As Mike said the RED is the way to go. Bolt it up and have fun. No lag and worry free. It has been proven the RED is a very capable turbo. If I owned a street evo the RED would be the turbo hands down.
Old Mar 28, 2009 | 02:03 PM
I want to add one more thing. Everyone keeps saying 35R gives you more room down the road. Both only give you more room if the motor and mods are there to support it. My RED made 631 so I know it makes plenty of power. Dont buy a 35R and just trun up the boost. Your limited with both turbo's at 500 whp due to the motor. Both turbos can make 500 without blinking and the red bolts right up. Just an FYI...
Old Mar 28, 2009 | 02:08 PM
NomadMR's Avatar
Talking
really it depends on price range. the red is high on torque and is great for street but i have a 3o76 on e85 and is awesome but more expensive for the whole setup. The plus side theres room for way more improvement when you get the setup. But with red, your pretty much at end and who wants to ride on a maxed out red every day boost wise, cause who under tunes, every one goes for the gusto. I have respect for the red but am satisfied with my 30r . GOOD LUCK>
Old Mar 28, 2009 | 02:27 PM
bbyevo8u's Avatar
dont want to hi jack here but can someone tell me what other mods i need for replacing my stock turbo with either red or green turbo? my mods are below
i know i need (front mount, head studs, injectors, clutch) but what else should i can for a safe setup? i have a stock engine/trans do you think its ok to run this type of setup with the stock engine & trans it know the 6sp is a bit weaker than the 5sp
hope someone can help me here, thanks!
Old Mar 28, 2009 | 03:19 PM
Respo's Avatar
if you not do anything to motor I think getting Red is the best to do it.
but if you want to built motor do 30r or 35r.
Old Mar 28, 2009 | 05:01 PM
sizzflair's Avatar
this has been the questions for me as a future evo owner.
Like others have said already...
Street - Red
Track - 35r
unless.. you go all out with engine build. If that's the case, get 35r while you're at it since you'll probably max out the red before 35r
Old Mar 28, 2009 | 07:32 PM
1d10t's Avatar
My vote is the red. That is, unless youre going to build the engine. In that case, you could still go red and run higher compression
Old Mar 30, 2009 | 07:27 AM
bbyevo8u's Avatar
umm were can you buy a red/green turbo??? cant seem to find it anywhere
