no boost slow boost
i dont know what you guys mean. this is how i did it.
http://www.hallmanboostcontroller.com/howto.html
ok what he was talking about if you look at the last picture B.) is your wastegate and A.) is the turbo outlet from the j pipe that he was just nit picking on you lol. did you try turning it up quite some?
https://www.evolutionm.net/forums/at...gram-3-drb.jpg
on there you see the bcs that line should be rerouted to itself theres two outlets. now if you look you can see one of those lines was going to the mas Pipe that end of the pipe should be capped off.
yeah i have all that capped off. i have it like it should be i think. im thinking about maybe running stock boost controller just to see. and im gonna try my friends mbc. ill keep you posted.
well heres how you make one
https://www.evolutionm.net/forums/ev...er-5-02-a.html
or you can buy this one which is a really nice but expensive
http://www.paradigmperformance.net/p...boostleak.html
and what your gonna do is take your intake pipe off and put this on cold side of the turbo and fill with psi from a air compressor (i would run like 25-30psi into there and then when theres that amount in there listen for air coming out of anywhere, make sure the coupler is clamped on tight because it will blow off if not. you can put soapy water on areas to and if you see bubbles then you got a leak. this is prolly the best way to find leaks and you would want to do this before a tune anyways.
