no boost slow boost
Old Mar 28, 2009 | 06:38 PM
MIVEC 4G63's Avatar
no boost slow boost
i dont even know where to post this anymore, but here it comes. i just put in brian crower cams in my ix with no tune and a manual boost controller. the car doesn't want to boost. it boosts very slow and barely reaches 15psi.
Old Mar 28, 2009 | 06:40 PM
N3VO's Avatar
check for leaks make sure you installed your mbc right sounds like you have it backwards.
Old Mar 28, 2009 | 06:58 PM
justa4banger's Avatar
check for leaks
Old Mar 28, 2009 | 07:15 PM
godmiller10's Avatar
um...? idk if i would be romping on it with cams and no tune. Take it to get a tune and just get them to fix the mbc, would only take a few mins.
Old Mar 28, 2009 | 07:17 PM
MIVEC 4G63's Avatar
but if a had leaks i would have heard one. im gonna try to switch the mbc hoses around now and see what happens. i have the mbc connected to the intake on the turbo and actuator.
Old Mar 28, 2009 | 07:18 PM
MIVEC 4G63's Avatar
would i hit 15psi with hoses switched around the wrong way?
Old Mar 28, 2009 | 07:19 PM
N3VO's Avatar
yes thats correct but what mbc do you have? you have to make sure the lines are going to the right ports on the mbc
Old Mar 28, 2009 | 07:21 PM
MIVEC 4G63's Avatar
halmin i think its spelled
Old Mar 28, 2009 | 07:26 PM
jjm4life's Avatar
its hallman. and odds are you wont hear a boost leak. vacuum leak, sure.. but a boost leak you need to test for that. and dont get on it until you're properly tuned.
Old Mar 28, 2009 | 07:28 PM
N3VO's Avatar
hallman well look up the which line the turbo is supposed to go to and wastegate outlet is supposed to go to. i have a forge so its different.
Old Mar 28, 2009 | 08:33 PM
MIVEC 4G63's Avatar
i just tried it both ways and still nothing. 6k rpm = around 15psi. boost is coming on real slow and it feels like im driving n/a. wow im gonna go crazy here.
Old Mar 28, 2009 | 08:37 PM
N3VO's Avatar
how many turns did you do?
Old Mar 28, 2009 | 08:40 PM
sparky's Avatar
Originally Posted by MIVEC 4G63
....i have the mbc connected to the intake on the turbo....
Naw, you don't have it connected to the compressor inlet. Instead, you must have the hose connected to the nipple located on compressor discharge tube, aka the "J" tube.
Old Mar 28, 2009 | 08:43 PM
N3VO's Avatar
i think thats what he meant
Old Mar 28, 2009 | 08:49 PM
sparky's Avatar
Yeah, I too understood that he meant to write compressor, and, not intake. I was just being a nit picker.
