Problem after Clutch Install...
Ok guys, I finished installing my Exedy Stage 2 clutch and flyweel today and it drove fine. But after about 20 min of driving it started making this weird vibration almost like the driveshaft is off balance or something. Its like my tires are completely off ballance all of a sudden. I doubt it's my tires so what do u think it is?
It seems like IDK like the driveshaft is spinning off balance and its vibrating or spinning off a little and making the car shake a lil and giging off a bit of a low frequency hum. Almost like I have a Subwoofer in my car really loud with lots bass. It only happens after 50mph but before it's fine. And after about 75mph it calms down a lil but its still there. Also, once in a while I hear this loud thud from the rear of the car when I shift gears, and I wont even be shifting hard.. Like its a bang when the gear goes in from the rear diffy or driveshaft or something. IDK
PLEASE HELP!!!
PLEASE HELP!!!
are you sure you did "EVERYTHING" step by step??? like the pressure plate or flywheel being torqued in the right order with the right torqued specs? and did you use the blue glue thingy for the flywheel bolts?
