Mystery Camshafts...Help Identify
Old Mar 28, 2009 | 10:58 PM
heel2toe's Avatar
Hello,
I purchased a set of camshafts on here which were supposed to be HKS 272's Unfortunately there are no marking on them other than the number one. The number is engraved on both cams. Here is a picture. Anyone familiar with these cams?
Old Mar 29, 2009 | 12:50 AM
Chris@nolimitmotors's Avatar
Any other pics?
Old Mar 29, 2009 | 06:56 AM
heel2toe's Avatar
I can snap some more photos if that would help. In all honesty they are going to look like any other set of cams. Besides the number one which is posted above there are no other markings.
Where specifically on the cams should I take photos of?
Old Mar 29, 2009 | 07:20 AM
rsboy's Avatar
Doesn't HKS cams have "HKS" stamped on their cams?
do the cams have different looking ends? At least they are not stock cams.
Hope you get it sorted out.
Old Mar 29, 2009 | 07:23 AM
Evo8Emperor's Avatar
Seems like you got scammed with a stock pair of cams. Just take off your valve cover and compare.
Old Mar 29, 2009 | 07:49 AM
heel2toe's Avatar
I sure hope these arent stock cams. My head is coming off in the next couple of days so I will be able to compare them with the stock cams.
Both cams have the number one engraved on them and there is both an intake and exhaust cam as one has the slotted end. Any other ideas of what they are? I can take pictures of any specific area if it would help.
Now I am aware that the stock IX cams were hollow. Is the same true for VIII cams as these are def not hollow?
Old Mar 29, 2009 | 08:18 AM
94AWDcoupe's Avatar
looks like stock cam, sorry
Old Mar 29, 2009 | 08:23 AM
Evil_Rs's Avatar
the intake cam will have the groove cut out on one end if it was stock (not sure with aftermarket)
MOST aftermarket companies engrave a name/size on the fat end of both cams.
Old Mar 29, 2009 | 08:34 AM
wevo1985's Avatar
are they hallow?
Old Mar 29, 2009 | 09:15 AM
heel2toe's Avatar
They are not hollow. One of the cams does indeed have a groove cut on the end. Are the VIII cams hollow or just the IX?
Old Mar 29, 2009 | 11:53 AM
JakeTheVIII's Avatar
stock evo 8 cams are hollow too
Old Mar 29, 2009 | 01:39 PM
heel2toe's Avatar
Well then I guess these are indeed aftermarket cams. The question is what kind? Someone else has got to of seen these cams before. Maybe there custom ground?
Old Mar 29, 2009 | 01:46 PM
dancarroll0283's Avatar
Well for sure they aren't stock cams, cause they are hollow... HKS cams are stamped "HKS" I did install some HKS cams for a customer on an Evo9, and the intake cam was stamped with only "HK" no s...... I've seens lots of cams, can you post up some more pictures??
Old Mar 29, 2009 | 01:49 PM
Steve93Talon's Avatar
Maybe they're stock DSM cams, they're look alot like VIII cams except solid.
Old Mar 29, 2009 | 02:33 PM
broeli's Avatar
Who did you buy them off of? Did you question them about it yet?
