Cam gear bolt snapped...thoughts?
Old Mar 29, 2009 | 02:54 PM
mitdrx's Avatar
I was finalizing a cam swap.. I was putting torque on the main bolt that holds the cam gear to the cam...when the head snapped off. I pulled the cam and I am taking it to a machine shop to get it back out. Do you think the cam has been compromised?
Old Mar 29, 2009 | 03:26 PM
Blkstreak's Avatar
What were you tightening it to? 65 ft lbs?
it shouldn't have snapped unless it was in crooked or you were using too much torque.
If they can get the rest of the bolt out, and you clean the threads with a thread chaser, the cam should be fine though.
Old Mar 29, 2009 | 03:55 PM
mitdrx's Avatar
I think I put too much torque on it because its in the cam almost the whole way.
Old Mar 29, 2009 | 04:09 PM
Blue Evo 8's Avatar
It happened to me also, I was using a cheapo tq wrench to do the job.
Get a few replacements from mitsubishiparts.net part # MF140285
and keep some handly just in case
Old Mar 29, 2009 | 04:11 PM
idriveanevo's Avatar
it should be fine... check threads, clean them and your good to go!
Old Mar 29, 2009 | 04:19 PM
mitdrx's Avatar
Thanks...you sir..are a gentleman
Old Mar 29, 2009 | 05:05 PM
Blue Evo 8's Avatar
You're very welcome. when I was reinstalling my cams, for some reason my tq wrench was out of calibration, and here I am throwing my whole body weight into it to tighten the cam bolt...I should have realized that if I am throwing my whole body weight into it that something is wrong.
Lesson learned:
1) buy good tools
2) keep a few spare oem cam bolts lying around just in case you snap one (since I swap out my cams frequently).
booster9
452
Jan 31, 2017 04:44 PM
powerspeed06
Mar 5, 2011 04:58 PM
EvolNinja
Jul 18, 2009 08:30 PM
MadCrix
Jul 17, 2007 08:36 AM
spyderx
Nov 23, 2005 09:52 AM
