2nd Gear lockout
Old Mar 31, 2009 | 01:08 AM
frycztech's Avatar
2nd Gear lockout
OK so first off i have a friend that has a 04 evo 8. He has been having problems with his trans. When he is at high rpms he gets locked out of 2nd gear any other time it is fine. He has gotten the trans rebuilt nothing, he did a exedy triple upgrade since he had the twin in and nothing. We tried switching the shifter cables nothing. We put in a totally different trans and still nothing. Then we did a stiffer motor mount and all the shifter bushing and having the same problem.
Please help
Old Mar 31, 2009 | 01:34 AM
Silversky88's Avatar
Did he push the clutch all the way in when his at high rpm and its still gets lock? If so I would check the clutch. i know some after market clutch can screw up the tranny.
Old Mar 31, 2009 | 04:55 AM
frycztech's Avatar
Yes the clutch is pushed all the way in. Other people have driven the car with the same results.
Old Mar 31, 2009 | 12:19 PM
frycztech's Avatar
Bump!
Old Mar 31, 2009 | 12:23 PM
SOEuro's Avatar
what fluid are you using??
Old Mar 31, 2009 | 12:35 PM
frycztech's Avatar
A blend of shockproof
Old Mar 31, 2009 | 12:42 PM
apagan01's Avatar
adjust the clutch pedal so the pedal is higher there is a how to do it in evomoto.com
most likely syncro is gone ver comon when you cant shift into a gear on high rpms.
gl,,
and get AMSOIL in that tranny fluid GL4 MTG
Old Mar 31, 2009 | 12:48 PM
frycztech's Avatar
The tranny was just rebuilt so i think the syncro's where redone but ill check on that.
Old Mar 31, 2009 | 05:31 PM
frycztech's Avatar
bump
Old Mar 31, 2009 | 05:56 PM
packed's Avatar
Friend had the same problem, flushed with AMSOIL. Has been fine ever since.
Old Mar 31, 2009 | 06:07 PM
vmrevo9's Avatar
Veteran: Air Force
amsoil does make a difference!! mine was notchy as hell until i switch to amsoil! get with apagan01 he'll hook u up.
Old Mar 31, 2009 | 06:12 PM
frycztech's Avatar
OK so try amsoil, the only thing that is wired is that there where two different trannys we tried and we know that one was good in another car(or so the person said)
Old Apr 1, 2009 | 04:56 AM
frycztech's Avatar
Bump. Anyone have any other suggestions?
Old Apr 1, 2009 | 12:20 PM
frycztech's Avatar
anyone?
Old Apr 1, 2009 | 07:22 PM
I would check the gears then
