Slowly using Coolant From Reservoir!?
Old Apr 5, 2009 | 12:26 AM
aguita's Avatar
Hello
I noticed a few weeks ago that my car use some coolant from the reservoir...when the car is cold I filled up to the full mark..after some hard driving the coolant in the reservoir goes a lil bit higher and when It cools down it comes down..But I have noticed that It's missing some since the coolant now is way below the full mark..?bad radiator cap???
No bubles
No Milky oil
No smoke
No overheat even beating the h... out of it on hot weather with A/C
what could be the problem? thanks
Old Apr 5, 2009 | 12:31 AM
SLO-EVO's Avatar
i really dont think you have a problem... if you pop the radiator cap, and its full, sounds like everything is just fine to me... now if its low when you open it, you may have a small leak somewhere...
Old Apr 5, 2009 | 04:22 AM
Evo8Emperor's Avatar
Sounds like that radiator cap. I have the same problem and I have pressure tested my coolant system and everything was fine. So the only thing left is the radiator cap. Make sure you dont have it tightened all the way down because it needs to vent that is also another problem.
Old Apr 5, 2009 | 07:34 AM
barneyb's Avatar
The Radiator cap is a service item. I had a pressure cap tester for so many years I wore it out. Anyway, the caps on average are good for about 30,000 miles which means the radiator caps on most cars are shot. So, it is a good habit to replace the cap when changing coolant.
A cap that is allowing vapor to escape will cause the coolant level to go down but only slowly.
Old Apr 5, 2009 | 07:43 AM
JKD's Avatar
JKD
Your problem might not even be a problem. I would check for leaks first.
Old Apr 5, 2009 | 08:33 AM
aguita's Avatar
thanks for the inputs...No leaks whatsoever coolant on the rad always full...No dripping or anthing no signs of leaks..
Can I use a 1.1 Bar Cap?
Old Apr 5, 2009 | 11:31 AM
barneyb's Avatar
1.1 bar is incorrect usage of the term. 1 bar is approximately atmospheric pressure so 1.1 bar would be almost no pressure - the pressure in a flat tire. 1.1 barg (meaning 1.1 x close to atmospheric pressure) would be 15.9 psi which is the correct pressure cap for the Evo.
Old Apr 5, 2009 | 06:55 PM
aguita's Avatar
!?I found a NIB rad cap here in my house that fits the evo and it says 1.1 and the evo one says 0.9..
dn788
Apr 17, 2017 10:13 AM
changocox1322
Feb 24, 2016 07:09 PM
eus_evo8MR
Feb 13, 2013 10:20 AM
racer135
19
Feb 1, 2009 08:57 PM
musca999
May 10, 2006 09:17 PM
