Megan o2 housing different than the old ebay o2 housing?
Old Apr 6, 2009 | 08:38 PM
neonglh's Avatar
I was reading an older post from David Buscher from 2005, and he had wonderful results with the eBay o2 housing:
Below is the dyno graph. It's pretty amazing. This is on PUMP GAS and has been all day! The car gained 13 whp and 12 ft lbs of torque.
Those gains of 13 whp and 12ft/lb are wonderful! Back in the day, people said the megan racing housing was the same as a few others, including what they called the "ebay o2 housing". I later read that Buscher said they can no longer find these good o2 housings on ebay anymore.
What is the deal? Are the current Megan Racing o2 housings any different than the ebay o2's of the past? It would be great to get those type of gains today, without paying out our asses.
-mark
Old Apr 6, 2009 | 08:55 PM
4G63K's Avatar
They are still the same. I think. You buy them port and coat them and you will get those gains.
Old Apr 6, 2009 | 08:57 PM
neonglh's Avatar
I don't want to port it due to its already thin walls, but it is nice to know the design wasn't changed too much from back in the day.
Old Apr 8, 2009 | 07:26 PM
sslevo's Avatar
I just got an "ebay" housing, it will need a lot of work to clean it up. Spent 1 hr tonight and it will probably need another hour. I had a used megan unit but thought i wasn't going to use it and sold it, that was a much better piece. This should work ok i just need to blend in a bunch of welds. The opening from the wastegate side to the exhaust side was very small and odd shaped, should have taken a pic. So i pretty much got that opened up and blended in.
Old Apr 8, 2009 | 07:47 PM
N3VO's Avatar
yes the megan is alot cleaner and doesnt need work done to it, the inside of it is already smoothed out
Old Apr 8, 2009 | 08:07 PM
Bster13's Avatar
Is this the correct Megan O2 housing?
http://www.maperformance.com/megan-r...using-evo.html
Old Apr 9, 2009 | 12:37 PM
N3VO's Avatar
sure is thats where i got mine from
Old Apr 9, 2009 | 12:38 PM
Bster13's Avatar
Did you port it afterwards? Any boost creep issues I keep reading about? thx.
Old Apr 9, 2009 | 12:40 PM
N3VO's Avatar
never installed mine because just didnt have the time and doesnt need port work done to it wont really make a difference, and as for boost creep i have no clue cause never installed it but ive only heard good things about it.
Old Apr 9, 2009 | 12:42 PM
apagan01's Avatar
megan o2, i made 7 ponnies
Bster13's Avatar
non-ported, or as is?
Old Apr 9, 2009 | 12:45 PM
N3VO's Avatar
non ported you will make that, i honestly dont see what could be ported in there
Old Apr 9, 2009 | 06:45 PM
sslevo's Avatar
There really isn't any porting to be done with a quality housing. The "ebay" housing doesn't recieve much work on the inside of the housing. They grind/ polish the outside but the inside still needs work.
Old Apr 9, 2009 | 09:31 PM
evo unknown's Avatar
i actually just ordered an ebay o2 housing to install when i install my tbe. i'll let u know how mine turns out..i hope it is good quality b.c it is a difficult and time consuming part to install.
Old Apr 9, 2009 | 09:52 PM
sslevo's Avatar
If you got it from the same guy i did it is going to need some work, haha.
TomekEVO
20
Jul 28, 2014 03:46 PM
Svendiesel
195
Jan 24, 2012 10:46 AM
Anubis18
19
Nov 11, 2011 04:20 PM
HFA_Ultima
38
Nov 18, 2010 03:24 AM
Bster13
10
Jan 29, 2009 08:27 AM
