Car Jerking at WOT
Old Apr 10, 2009 | 01:38 PM
mystik_khmer's Avatar
ignition
Old Apr 10, 2009 | 01:44 PM
AF-Evo8's Avatar
do you have the full k&n typhoon intake ( pipe and filter) or just the k&n filter?
Old Apr 10, 2009 | 01:47 PM
ev0lution9's Avatar
i would think that its boost or fuel cut like someone else said cause your not tuned yet get a tune
Old Apr 10, 2009 | 03:54 PM
Silvermike's Avatar
I recently had a similar problem. I changed plugs, ignition wires, and then finally firgure out it was the coils.
you can start by checking ure plugs, make sure ure running proper gapping (.022") etc. Hope its not ure coils, they are the most expensive fix ..
Old Apr 10, 2009 | 09:34 PM
Fknfstevo's Avatar
I'm on my phone at work so its kinda hard to see every post bust definately upgrade your plugs. A guy I know went as far as full basic bolt ons + fp red on stock plugs and the realized that "o snap, I need better plugs" gl
Old Apr 11, 2009 | 03:12 PM
Nkryptd1's Avatar
Good news! Im back up and running. The plugs were definitely the problem. Thank you everyone for the help!
I plan on hitting the Dyno and getting a tune by the end of May hopefully
Old Apr 12, 2009 | 08:19 PM
anthony_86gt's Avatar
Thanks for posting the fix. How often should the plugs be changed?
Old Apr 12, 2009 | 08:26 PM
bluebanana23's Avatar
change out the stock dv to a evo 9 one asap as the plastic viii tends to leak pretty early on the boost
butte
Nov 12, 2015 04:23 PM
Syrihl
11
Feb 4, 2012 02:32 PM
LaXGSR
13
Oct 1, 2010 08:26 AM
mirXa
Aug 30, 2010 11:57 AM
8-BallEvo
13
Jan 14, 2010 05:31 PM
