Car Jerking at WOT
Car Jerking at WOT
Hey guys! Just looking for a little help or advice.
Recently I decided to do some spirited driving and got on it, wide open throttle (WOT), in second gear and the car was running fine til about 4k. At 4k the motor felt like it stopped or something for a split second then continued on un interrupted. Prior to this happening I had my rear O2 sensor go out on me which I don't think would be the cause.
Anyhow, I changed out my O2 sensor today for kicks and the car still stutters. I searched around EvoM a little and found mentions of clutch going out, fuel cut, and boost cut. I can't see why it would be fuel or boost cut cause no new mods have been added to the vehicle in a while. Im really hopeing its not the clutch because it was recently replaced 6k miles ago and I haven't launched once on the new clutch. Plus if the clutch was going out wouldn't I see my RPMs spike up when the car jerked instead of pausing or falling?
Im kind of clueless and still a newb so any ideas or recommendations for trouble shooting this issue would be greatly appreciated.
Thanks in advance
Mods Include;
Test Pipe
K&N Intake w/ MAF attached
Downpipe
O2 Housing
Walbro 255
Not Tuned Yet...
I know, I know not tuning is my first mistake
Thanks in advance
Mods Include;
Test Pipe
Downpipe
O2 Housing
Walbro 255
Not Tuned Yet...
... The rear O2 had a wire get pinched off by the chassis cause of the O2 defouler. I know newb mistake.Thanks for the advice so far guys. It looks as though Ill start around the intake area and work my way back looking for leaks. Any others please chime in as well.
check your sparkplugs?
running too rich or massive knocks can cause similar sympton (pull timings).
It's happening at peak boost so more likely those above.
definitely not fuel cut because you'll know it.
definitely seams like an ignition missfire. Check the plugs and condition of the wires. Be carefull when you take the plug wires off, you only wanna pull on the rubber boot not the actual wire itself.
i agree on ignition too.
check the plugs, but also check the wires and coil packs. I had an annoying breakup in my Supra for a while and finally inspected the coilpacks one by one and found tiny hairline cracks in the tips. was just enuff for spark to jump and cause the car to go crazy in boost.
