HKS TWIN POWER ign
Old Apr 12, 2009 | 12:30 PM
skatermsmn's Avatar
HKS TWIN POWER ign
I was wondering if anyone has installed the hks twin power ignition system on there car, I got it used and dont have a diagram for the hookup I know its plug and play but there are 2 black wires that need to be put somewhere.
Old Apr 12, 2009 | 12:41 PM
chaotichoax's Avatar
I would make an assumption and say that they are grounds
do they have plug and play connectors on them or what?
Old Apr 12, 2009 | 01:15 PM
evokid511's Avatar
yeah blacks usually ground if its just a wire but if it has a connector on it then i woul assume it plugs into something else instead
Old Apr 12, 2009 | 09:50 PM
skatermsmn's Avatar
It is the plug and play, I was just wondering cause there are 2 of the black wires. I will ground those 2 and give it a shot.
Old Apr 13, 2009 | 12:15 AM
Monkeysphere's Avatar
I have the HKS DLI II on my car. My unit has an earth wire coming from the HKS Amp that is bolted onto my chassis. It then has a sleeved loom with 4 plugs for the OEM coil packs. That's all the wiring that mine had. Hope it helps.
Old Apr 13, 2009 | 07:03 AM
WHTEVO's Avatar
YES, those two wires are ground.
Old Apr 13, 2009 | 08:39 PM
skatermsmn's Avatar
Is the light on the box supposed to stay lit red at all times?
Old Apr 13, 2009 | 09:08 PM
WHTEVO's Avatar
With the key out? No it is NOT. If you'r car is on, then yes.
Aaron
Old Apr 13, 2009 | 09:16 PM
skatermsmn's Avatar
Aaron
Ya thats what I meant. Its only on when the car is on, do I need to do anything with my aem ems to configure this with the coil dwell?
