o2 housing install- sensor now hitting AC line?
Old Apr 16, 2009 | 11:48 AM
igo4bmx's Avatar
Not sure why but the o2 housing i purchased has the o2 bung welded near the DP and so when bolted up it hits the AC line. Anyone has this problem on their o2 housing? I am wondering if i can just bend the line a bit i guess...
Old Apr 16, 2009 | 11:49 AM
tim85851's Avatar
bend the line a little bit...but if i remember correctly nothing should be in the way...
Old Apr 16, 2009 | 12:03 PM
igo4bmx's Avatar
most o2 housings have the o2 sensor bung welded here...
my bung is welded near the base of the o2 housing near where the DP connects.
Old Apr 16, 2009 | 12:20 PM
jjm4life's Avatar
what o2 housing did you get james? ive never seen one with the bung where you describe it. id assume you can just bend the line as long as you dont kink it though. still, id be weary of a poorly designed o2 housing
Old Apr 16, 2009 | 01:05 PM
leecho's Avatar
I don't think I've seen an O2 housing posted on here with the bung welded where you're describing. I can see where it would cause a problem in the position you're describing. That's strange.
Old Apr 16, 2009 | 01:17 PM
xmaciek82x's Avatar
IIRC some early ebay ones had this problem a while back. What o2 housing you running?
Old Apr 16, 2009 | 01:53 PM
igo4bmx's Avatar
some cheapo ebay one i got used.
Old Apr 16, 2009 | 07:51 PM
Craig King's Avatar
Speaking of o2 housings, where is a good place to get the gaskets for an aftermarket housing?
Old Apr 16, 2009 | 07:59 PM
xmaciek82x's Avatar
Maybe it was one of those first batches I remember people having issues with.
Old Apr 17, 2009 | 06:16 AM
igo4bmx's Avatar
so can i bend that line or do I need to buy another o2 housing?
