HKS SSQV VTA with 272 cams
Old Apr 20, 2009 | 05:09 PM
ablan029's Avatar
I currently have the HKS SSQV set up to VTA with no problems. But I'm installing HKS 272 cams soon and I understand that in everyday normal driving it will cause low RPM drop downs when coming to idle after going WOT or POSSIBLY EVEN CUT OFF WITH THE 272s!! I know some people say they work fine VTA, but they have learned to drive around the low RPM drop down or stalling issue. How should I change my driving style to minimize these problems if I don't want to recirc??
Old Apr 20, 2009 | 05:58 PM
SLUG LIFE's Avatar
dont cut the gas and stop quickly when u get of the gas and pull out of gear and hit the brakes the vacum is weak and the engine can stall.
Old Apr 20, 2009 | 06:57 PM
ablan029's Avatar
so basically just keep my foot on the gas?? seems kinda digressive
Old Apr 20, 2009 | 07:17 PM
MissionSk8r21's Avatar
yea I have the hks ssqv and kelford 272's. Its got its issues, but its really not that bad. Just takes a few more cranks to start, and has a loopy idle.
Old Apr 20, 2009 | 10:22 PM
BlownIncome's Avatar
What type of issues are you (or anyone else with the hks bov) having with this bov if you don't mind me asking, and is yours set up to vta or recirculate? I'm about to purchase another bov and I have been considering the hks or forge bov's. I'm running hks 272's and currently have my boost at 28 lbs. but want to push it to about 30 or 31 lbs. Sorry if this is
Old Apr 20, 2009 | 10:31 PM
brokenRS's Avatar
if your running stock maf, without a doubt, run it circulated.
Old Apr 21, 2009 | 10:23 AM
ablan029's Avatar
aside from using a blow through MAF or an EMS are there any other options of replacing the stock MAF??
Old Apr 21, 2009 | 10:26 AM
chaotichoax's Avatar
visit the ecuflash forums...speed density is now possible
otherwise lose the bov
Old Apr 21, 2009 | 10:30 AM
lancersibling's Avatar
I am running a HKS SSQV bov and HKS 272 cams with turbo/ fuel upgrade. I have been running my car since September 08 and have had less than 5 stall issues. If I feel it getting low in the rpm, i blip the gas. I have done a few drags with no issues from WOT to braking. I guess it depends on the car and the tuner. I would recirc if possible unless running speed density. In my case, without details, I had no choice due to time limitations but to run VTA. My car runs great and I consider myself lucky.
Old Apr 21, 2009 | 10:42 AM
slvrr's Avatar
Why would you want to replace it? I have the Synapse on my car recirculated and its more than loud enough. Hell it scares old people walk/driving beside me haha
Old Apr 21, 2009 | 11:33 AM
ablan029's Avatar
i figure the ssqv is a VTA blow-off valve because of it's diaphragm design and its beautiful sound. i would seriously rather dish out the extra money for a blow through as opposed to recirculating it.
EVOX2NV
Dec 21, 2015 06:15 PM
matizzay
Nov 3, 2011 07:51 PM
nobodyphil
80
Mar 16, 2011 07:35 PM
yellowrocket
Northwest Region
14
Apr 21, 2009 03:56 PM
inline4g63
Feb 14, 2004 05:48 PM
