Evos do not like moisture
Old Apr 23, 2009 | 09:03 PM
Malik_EvoIX's Avatar
Seems like every time i have my car on my driveway overnight ( it is spring in MI, and a lot of rain) when i start my car squeaking noise comes from my timing belt area! but now it does not happen it was dry today! happens when it is also raining!
Old Apr 23, 2009 | 09:07 PM
AJsGenerX's Avatar
Tighten up your serpentine belt. My mothers lancer would squeak after driving through a puddle or anytime water has hit the belt.
Old Apr 23, 2009 | 09:10 PM
compscibOi's Avatar
Same for me if I wash it and don't cover the hood. Doesn't do it when it's dry tho. Odd.
Old Apr 24, 2009 | 07:44 AM
barneyb's Avatar
How do you do that?
Old Apr 24, 2009 | 01:21 PM
i want to know too
Old Apr 24, 2009 | 02:19 PM
cudaman07's Avatar
me three
Old Apr 24, 2009 | 02:23 PM
Raceghost's Avatar
There is a tensioner on it somewhere, if not, loosen your alternator bolt, and twist it out until the the belt is taught. Your alternator should be on a little slide thing, that will adjust for a loose belt, I think, don't quote me here. But that is standard on most cars...
Old Apr 24, 2009 | 02:37 PM
heel2toe's Avatar
How can you tighten the belt if there is a tensioner on it? I thought the point of the tensioner was just like its name, to keep tension on the belt. And the fact that its spring loaded enables it to adjust.
Im pretty sure there is also some type of spray which helps to reduce the squeaking of the belts.
Old Apr 24, 2009 | 02:53 PM
kapture2k's Avatar
How many miles does your car have? I live in Miami and it rains all the time and i have never had this problem.
Old Apr 24, 2009 | 07:07 PM
AznDragonV's Avatar
i dont think u can tighten the tensioner becuase it is auto tensioned.. it can only be loosened and then unloosend to let it go back into tension.
( you put a 1/2" driver in the square hole and turn to untension)
Old Apr 24, 2009 | 07:17 PM
electricevo's Avatar
check to see if your accessory belt has cracks. If it does its time for a new belt. Also, check to make sure the tensioner is keeping enough tension on the belt.
Old Apr 24, 2009 | 07:25 PM
idriveanevo's Avatar
evos do not have adjustable tensioners. its an automatic tensioner. the alternator does not adjust at all.
Old Apr 25, 2009 | 04:39 AM
Originally Posted by kapture2k
how many miles does your car have? I live in miami and it rains all the time and i have never had this problem.
37,000
Old May 1, 2009 | 07:12 PM
bump
Old May 1, 2009 | 08:03 PM
biggie5252's Avatar
Mine did the same thing when it rained/was wet. It kept getting worse so I checked it out and the pulley was loose. I don't know if it was related, but tightening it helped but didn't eliminate it. I ended up getting a fluidampr and it still does it a tiny bit. The belt was fine also, no cracks or anything. I'll be replacing the belts later this year and I imagine it'll stop squeezing for good.
