CAT problem
Old Apr 26, 2009 | 03:59 PM
Jimevo9PI's Avatar
CAT problem
Hi folks! I got a little problem with my Evo right now. My car is due for emission inspection this coming June and here in Georgia you need a catalytic converter in order to pass the emission. I got a fully built Evo 9 MR, my downpipe is magnaflow and my problem is I cannot install back my cat converter because I lost it when we moved to our new house. Can somebody give me an advice as to what kind of good CAT am I going to use and a cat back in order to pass the emission?
Thanks! All your advice are greatly appreciated.
Old Apr 26, 2009 | 05:19 PM
N3VO's Avatar
look for a stock evo 9 cat and dp on here, i have an 8 one but idk if they are the same
Old Apr 26, 2009 | 05:28 PM
gdup's Avatar
is ur check engine light on? My cuzin has no cats on his srt4 and passed easily. Guy plugged the computer on and that was it.
Old Apr 26, 2009 | 06:30 PM
Jimevo9PI's Avatar
Really? How the heck was that? I mean, how can you pass if you have no catalytic on? Btw, I have no engine light on.....
Old Apr 27, 2009 | 06:30 PM
EvoFlash's Avatar
If there's no check engine light as long as they don' look under there it will pass.
Old Apr 27, 2009 | 07:13 PM
Jimevo9PI's Avatar
I'm not sure it will pass because everytime I crank up my Evo 9(especially in the morning) there are some black carbon that is coming out of the pipe and I noticed that it has more smoke coming out than a regular car.
Old Apr 27, 2009 | 09:47 PM
hokiruu's Avatar
You options are:
- Buy a cat. If the cops are dicks there and you want to make sure you pass and its a good cat, run it.
- Buy a cat. If the cops/ emissions are laid back there and its a good cat, just install it for the test and put the testpipe back on after you pass.
- Camouflage your test pipe to look s like a cat and it might pass visual. No guarantee on smog but that's a different story.
- Just go get tested anyway with your testpipe in its tespipe obvious glory and hope for the best. Remember though, just because someone passed emissions because they didn't bother to look under the car (i.e. skipped/incomplete visual inspection) doesn't mean you should bet on it. Be prepared to get denied and be back at square one.
Some of the best and highest flowing cats are from Ciro Designs or Mil Spec (same) on this forum. Skip the Catco and Random ones, they aren't worth the losses and IMO you'd be better off just using a stock one for the test and swapping back to the TP after. if you can get away with that.
Old Apr 30, 2009 | 06:34 PM
Jimevo9PI's Avatar
Thanks for the advice. Hopefully I pass.
Old Oct 10, 2009 | 03:05 PM
tiresmokindad's Avatar
Sorry for my ignorance, I really need help. I was confused if the magnaflow catalytic converter is pretty good?and also where to buy? I do some searched, inguiry and I tried it here Magnaflow Catalytic Converter . Anyone tried it here.? Any suggestions, please let me know. Thanks.
Old Oct 10, 2009 | 06:59 PM
hokiruu's Avatar
IIRC the magnaflow isn't particularly high-flow for turbo cars and is a pretty big restriction. I could be wrong though. Oh, and it's defnintely not worth $570!
