compression test results???
Old Apr 27, 2009 | 03:51 PM
AKEVOIX's Avatar
did some searchin on numbers and just curious. i got 155psi on 3 cylinders and 145 on another. i see most people get 170ish. motor was moderately warm. the numbers are lower than most but the psi across the board was within 10psi. so i wonder if anyone else has seen these numbers or maybe my gauge reads low(brand new gauge by the way).
Old Apr 27, 2009 | 03:53 PM
RoadSpike's Avatar
I've been told just having consistency is the best way to look at it. Most of the time the compression testers are just cheapo units and they don't even match from set to set.
Cams, altitude, and having the throttle open while testing also have an effect. I think your motor is likely in great shape.
Old Apr 27, 2009 | 03:55 PM
AKEVOIX's Avatar
sweet thanks. i just bought the car with 20k miles so thats what i was hopin. schucks special tester
Old Apr 27, 2009 | 05:43 PM
EM1 to EVO's Avatar
Your numbers are fine. The 170 numbers you're reading about about are for the guys with VIII's, you have a IX, your numbers will be lower because you have MIVEC. I'm not sure off the top of my head what the acceptable range is for the IX, but I believe your numbers are on the upper end of the spectrum, and they're consistent so you are good to go.
Old Apr 27, 2009 | 06:41 PM
4drboost's Avatar
Also if you have cams, it will change compression
McKenny14
Oct 17, 2014 01:15 PM
Nomad4g63
17
Apr 1, 2008 11:43 AM
Smogrunner
Sep 25, 2006 09:57 PM
CO_VR4
Aug 25, 2006 11:48 AM
EvoRs
Jul 10, 2004 11:07 AM
