Need help!!!ACD probleme
Old Apr 28, 2009 | 11:51 AM
l EVO n's Avatar
https://www.evolutionm.net/forums/ev...ed-my-car.html
The link above is the link about me crashing my car
ok so i took it to get it fixed
i have to find all these parts online and purchase them because im the only evo owner in my country , so far im trying to find this (check out the pictures) in picture ACD 6 location is showing were the part is located (sorry the car picture i used isnt mine i just had that picture saved and the part was a little visable & i have the same exact evo i think)
parts i need pm me anyone if you can sell me anything
drivers side head light plastic cover (just the plastic cover the lights work fine)
radiator fan
IC
Attached Thumbnails Need help!!!ACD probleme-acd-1.jpg   Need help!!!ACD probleme-acd-2.jpg   Need help!!!ACD probleme-acd-3.jpg   Need help!!!ACD probleme-acd-5.jpg   Need help!!!ACD probleme-acd-6-location.jpg
Old Apr 28, 2009 | 12:01 PM
l EVO n's Avatar
and also ppl can you help me find that part and the fluid for it?
if i drive the car without that & the fluid what can happen?
Old Apr 28, 2009 | 12:02 PM
l EVO n's Avatar
And i think the 3 lights lit up after i removed the part
Old Apr 29, 2009 | 11:32 AM
l EVO n's Avatar
bump!
Old Apr 29, 2009 | 03:08 PM
Betty's Avatar
The 3 lights on your rpm gauge will all light up if the plastic container behind the driver side headlight is empty. You have to replace it and add the correct fluid and that problem should be fixed.
Old Apr 29, 2009 | 03:11 PM
rolly1818's Avatar
Registered User
you would need to drain the system as well right? before refilling that is!
Old May 1, 2009 | 02:43 AM
l EVO n's Avatar
i dont think i would have to would i?
Old May 1, 2009 | 06:32 AM
rolly1818's Avatar
Registered User
if its below where u can see fluid i recommend u bleed the system and then refill. if its just low then top it up.
Old May 2, 2009 | 01:05 AM
l EVO n's Avatar
so where do u think i can buy the part? is there an upgrade for that as well?
Old May 3, 2009 | 11:45 AM
l EVO n's Avatar
also i would like to know if i can drive the car without that part and fluid for a while till i get the part and fluid........................ any help guys?and what can happen if i drive the car without the part and fluid>?
Old May 4, 2009 | 12:49 PM
l EVO n's Avatar
so no one wants to help out or is it that no one understands?
Old May 4, 2009 | 01:03 PM
rolly1818's Avatar
Registered User
i would help but i dont know of the USDM ACD setup that much. my car is JDM.
the reservoir u have in the engine bay is for ur ACD?
Old May 5, 2009 | 10:28 AM
l EVO n's Avatar
yes .... the part that broke spilled out all the ACD fluid
Old May 14, 2009 | 07:39 AM
l EVO n's Avatar
bump!
Old May 14, 2009 | 07:44 AM
detroit pistins's Avatar
don;t drive when the acd reservoir is empty , u might end up starvingthe system and it cause issues with ur acd unit and transfercase. u can u se automatic transmission fluid that is made for imported cars. not sure where you are, but ur safe to use automatic tranny fluid and not having to drain the system (atleast to my knowldge). check with someone else just to be sure.
gl
