what is the stock psi does evo go
Josh:
thanks, very informative stuff.
If you want, I could take pics of the things you mentioned. Just tell me where to find them.
Will check out my injectors and do the fuel pump test.
how can I fond out the size of the turbo? All i see is TD05H.
Pls check my thread, "EVO2 from Japan, pls check mods" for a list and pics of suspected mods.
I really appreciate your help as I am totally clueless with this car.
Originally posted by evo2?
Josh:
Josh:
Since the Evo has only came with the 16G, it is either a large or a small 16G. One way of telling would be to take the turbo off from the exhaust manifold. Once you ahve it removed, measure the hole that runs between the manifold and the turbo. If it is 6cm wide, it is a small 16G. If it is 7cm wide, it is a large 16G.
Injectors:
Ok, in the picture that I have posted, look at the drawn in yello part. The long straight line will be where your fuel rail is. Your injectors will be mounted on your fuel rail. The 4 lines that go toward the valve cover are to simulate the injector placement. On these 4 injectors, you will have an electrical plug hooking to each one. The portion of the injector that the plug hooks to and everything above that and toward the fuel rail will be colored. The bottom part of the mwill be black. If the top is yellow, they are 520cc. If it is blue, they are 450cc. This is a color coding method that Denso used, which is the company that supplies the OEM injectors. Most aftermarket injectors are black on top and bottom, possibly gray. Also look at the picture at where I have circled the intake manifold in green. On your car, does your manifold say CYCLONE? Just curious. If so, you might have a really cool setup that I will get in to later on.
Oh, and I know my picture is junky. That was taken about a year ago, when I still had the car. It also has a T28 turbo on it because I was dicking around and playing with various turbo setups.
I took the picture from my Yahoo screenname briefcase, because I am not on my computer right now, and that is the only way I could find a picture of an early 4G63 to show you how it looks.
If you use Yahoo, you can add the screenname that is printed across the center of the picture and we could talk there, going into better detail about all of this stuff. You can also check out some pictures of my Evo and a few cars that I had before the Evo (GSX, rock crawling Jeep, slow *** Integra).
Hope this helps,
Josh
just checked the injectors, they are yellow. Also, there is no cyclone written. what does cyclone stand for?
P.S. You have 520cc injectors. They will support a big 16G turbo just fine. If you have the ability to datalog, check the duty cycle of these injectors under full boost. Make sure to keep the duty cycle under 85%. Any more than that and you are overdriving your injectors.
Josh
Originally posted by raywong
We have Jap version Evo here in Hong Kong and the stock Evo 7 here is 14.5psi all the way. I was told the Evo 8 are the same. We have 98 octane here in Hong Kong and even higher in Japan. Is that why Japan version has 280hp at lower boost?
Our jdm Evo 7s make 1.1 to 1.3bar of boost on 95RON gas.
I should really fit a boost guage......
after installing a boost gauge this morning, I was pleased to find that my evo hits a whopping 16 psi and then settles down to 15. now I finally know why this car feels like a slug.
Originally posted by webguy330i
<snip>
Example (not real, just hypotheticals):
94 octane US (R+M/2 method) = 100 RON + 88 MON / 2
98 octane non-US (RON method) will likely be closer to 91 octane using the R+M/2 method. Example:
98 RON + 84 MON / 2 = 91 PON (pump octane number, the result of the R+M/2 method of averaging RON and MON octane ratings)
<snip>
http://www.btinternet.com/~madmole/R...RONMONPON.html
98RON = 94 Octane
100RON = 98.5 Octane
95RON = 91 Octane
I'd appreciate if others post a similar website, because the one above doesn't give a "100% sure factor".
FS[Northeast]: Blitz SBD ID-3 Spec R
dolson222
46
Feb 19, 2015 01:52 PM
BeyondLimitsEvo
Northeast Region
Jan 30, 2012 09:38 AM
Nasty Evolution
Aug 17, 2010 11:26 AM
Madwheel
Sep 15, 2004 05:04 AM
