Removal of Motor,Tcase, Trans in one shot????
Old May 2, 2010 | 04:24 PM
BluEVOIX's Avatar
Quick question sort of on topic.
When unbolting and removing the transfer case only, does the transmission oil need to be drained?
I've changed the clutch twice before but need to attack the tc this time to replace that o-ring gasket because it leaks. I'm trying to avoid draining the transmission fluid but cant remember if its doable without draining the transmission oil.
Old May 2, 2010 | 04:46 PM
jmelocik's Avatar
Back on topic, Irwin (TiboEvo) and I pulled the engine, transmission and transfer case out of his 03 Evo as an assembly. It can be done with an engine hoist in the garage with the car on jackstands. You do not need to drop the subframe, nor do you need to take the t-case off.
Josh
Old May 2, 2010 | 05:24 PM
TIBOevo's Avatar
Josh
um, what he said.
Old May 2, 2010 | 06:03 PM
jmelocik's Avatar
Maybe I should correct that, he did all the work I just helped him get it out once everything was disconnected. LOL
Josh
Dallas J
Sep 10, 2019 11:45 AM
black_beauty
Jan 3, 2017 09:29 PM
ReidFletcher
Aug 31, 2016 10:37 AM
nor11384
Mar 2, 2016 02:51 PM
Adamk24
24
Aug 3, 2007 08:46 AM
