Backfire problem...
Old May 5, 2009 | 07:20 PM
Srt4...'s Avatar
Backfire problem...
I'm having a backfire problem in 3rd and 4th gear while full boosting only when i hit 4000rpms each time i wot. My mods are in my signature and I'm boosting 28psi. I havnt had this problem ever. My car is detuned at the moment since the meth has been disconnected. Could this be a possible boost leak or spark plug problem. Any help or suggestions would be greatly appreciated.
Old May 5, 2009 | 07:21 PM
chaotichoax's Avatar
change the plugs and see if it goes away...if your tune isn't up to par with the mods/fueling you are running you are going to be all out of whack
Old May 6, 2009 | 11:05 AM
evo8nfs's Avatar
I agree With That guy ^^^^^^
Old May 15, 2009 | 12:14 AM
Srt4...'s Avatar
So i have changed the spark plugs. Car runs better but still has backfire with hesitation at wOT at around 4000rpms. What else could i check
Old May 15, 2009 | 12:18 AM
dxbtune's Avatar
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
check your FPR , make sure your set to 43PSI with your finger on the vacuume after disconnecting it from the fpr...
Old May 15, 2009 | 12:21 AM
heel2toe's Avatar
possibly a boost leak? Do you have a wideband? Either that or you car just needs to be redialed in.
Old May 15, 2009 | 12:34 AM
TIBOevo's Avatar
i would close the spark gap alittle more. i would also recomend a ignition amp too.
Old May 15, 2009 | 07:27 AM
LV///R's Avatar
How many miles on your 03?
Have you changed your plug wires? I had a similar situation, and forgot to change my plug wires at 60,000 miles. Once I changed them, problem went away.
Other than that, when you changed your plugs, did you regap them to a lower gap? This is important especially if you are running high boost.
Old May 15, 2009 | 07:31 AM
AWD_Terror's Avatar
lower gap and checking for arcing on the plug wires will likely show you your problem
Old May 15, 2009 | 07:42 AM
D420mac's Avatar
No one thinks he could just be running rich?
Old May 15, 2009 | 12:09 PM
AWD_Terror's Avatar
doubt he is that rich to cause that.
Old May 15, 2009 | 08:20 PM
Srt4...'s Avatar
I jst hit 80,000 miles. I have not swaped out my wires yet that was going to be my second guess. When I put my new plugs evo8 9's i gapped them at .028 which was recommened here for high boost high horsepower evo's. I turned down the boost from 27 to 24 psi... I'll try the new wires and check my fpr. Question could I have a cut in my fuel map cause of a mishap on a tune since my car was originally running meth and no longer is now without a new tune? This problem occurs on wot at 4000rpms each time
Srt4...'s Avatar
Thx again for all responses and suggestions
Old May 15, 2009 | 08:23 PM
dxbtune's Avatar
Mine was randomly doing the same thing until i re-adjusted my FPR, it was way too high for some reason out of the blue...
