hks super sequential blow off valve need help
Old May 7, 2009 | 06:06 PM
evilrevo8's Avatar
hey guys i have a hks super sequential blow off valve and i was wondering what the screw was on the back and if i tighten it will it make it sound diffrent thnks guys
Old May 7, 2009 | 06:23 PM
evilrevo8's Avatar
aslo forgot to say im haveing troulbe with it stalling on me when i rev it up and aslo if im driveing and throw it into neutral do u guys have any things to help me to fix that problem
Old May 7, 2009 | 06:26 PM
Boost3dxEvO's Avatar
Not sure what the screw is for... but if you have this BOV on your car and it is NOT recirculated (which I am assuming because of the stalling) then you need to buy a recirculation kit for it.. or install the recirculation portion that came with it.. IMO this BOV is terrible for the evo's, especially if you are VTA with the stock maf in place.. put a stock metal 9 dv on your car or jdm metal dv... or aps twin vent if you using stock MAF..
Old May 7, 2009 | 07:21 PM
EvoDom's Avatar
you shouldnt have that BOV on an evo anyway......if you want a BOV sound by an intake and leave your stock BOV alone.
this BOV is the biggest peice of **** i have ever seen........everyone has problems with it.
who cares about sound....take it off........and its stalling because you do not have a tune for the BOV.
goodluck
research b4 you mod.
Old May 8, 2009 | 04:31 PM
evilrevo8's Avatar
goodluck
well i bought the car with is so im trying to fix it without takeing it off
Old May 8, 2009 | 05:48 PM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
You have an 03' and you can't run any BOV VTA if your running the stock ECU and MAF. Only the 05's and 06' can run VTA but then we run rich. You need to either recirculate your current BOV or purchase an APS Twin Vent which runs like stock and hold more boost. But the basic answer to your stalling issue is the BOV has to recirculate or your car will continue to stall. As for the screw wow that is the Ver. 1 SSQV. But the screw is there to control the spring pressure which controls how fast or slow the valve will open under partial boost. I had the same BOV on my 00' Turbo Civic and it was fine but only because there is no MAF on that car.
You also have a PM
Old May 8, 2009 | 05:59 PM
RedEcotecSS's Avatar
try out the forge recirc valve..
Old May 8, 2009 | 06:01 PM
idriveanevo's Avatar
get a aps dual vent or a forge recirculating valve and be done with it
Old May 8, 2009 | 07:25 PM
CO_VR4's Avatar
No, but if you duct tape a duck call to the exit it will
Old May 9, 2009 | 01:13 PM
Masterdebater's Avatar
+1 for the duck call...most comical **** on the road to date.
Flyhigh
Dec 6, 2016 06:38 AM
HKSUSA
Jul 14, 2015 11:23 AM
presti444
Nov 15, 2009 04:35 PM
