ARP L19 head studs 1+1... what to TQ???
Old Oct 6, 2009 | 12:43 PM
CO_VR4's Avatar
Originally Posted by evodan2004
when i installed mine or anyone elses i used impact tools.
Evodan, do you mean an impact socket with a torque wrench? Hope so.
Old Oct 6, 2009 | 12:49 PM
cij911's Avatar
Sorry, but I thought the L19s were a larger diameter and required machine work....I must have been wrong....Add that to the list ...
Old Oct 6, 2009 | 02:11 PM
PATRICK B.'s Avatar
Originally Posted by TitanMotorsport
As long as you're using the ARP Lube, I would say about 85lbs. 90lbs is a little much, & 95lbs is way too much. I would recommend about 84-85lbs.
It's been a while (you can try searching my name and L19's) since i posted about installing mine a year+ ago.
I could have sworn that the instructions i got from AMS/Titan Motorsports said to go in 3 increments up to 92lbs.
I remember for sure it was in the 90's just not exactly sorry
I used the lube
Funny how i bought these figuring i could re-use them and i have yet to seperate the head from block since it went together
By the way for the 12 point socket i use a deep 3/8" w/ to 1/2" adapter as it can be tight to fit a thicker impact socket in some spots.
Old Oct 6, 2009 | 02:16 PM
Ev0ikon's Avatar
Thumbs up
Now that you mentioned I did have to grind some of the washers off a bit on the outside to let them sit flush.
Bad idea to use a 3/8 to 1/2 adaptor in this application.
I have no problem using the 1/2" extension from HarborFreight though .:}
Old Oct 6, 2009 | 02:21 PM
PATRICK B.'s Avatar
Found the post about the tq spec 90 is what i posted 2 years ago.
https://www.evolutionm.net/forums/5003988-post40.html
Old Oct 6, 2009 | 02:23 PM
EvoDan2004's Avatar
nope i gun them right in. no need for all this trq talk.
haha jk. yes just a impact socket with trq wrench.
TitanMotorsport's Avatar
i didn't realized these were L19's. I got interested, so I called ARP
L19 head studs come in two different diameters 11mm & 12mm.
11mm require 90-95lbs tq
12mm require 110lbs tq
(as long as you're using ARP lube)
So it depends on the length of the head studs.
- FIXED -
cij911's Avatar
PatrickB - Are the L19s a different diameter ? Do you have to machine work and open up the holes in the head gasket ?
Old Oct 6, 2009 | 03:31 PM
PATRICK B.'s Avatar
The ones i got had no special install instructions i just sprayed them w/ some brakleen and installed to 90 ft/lbs w/ arp lube like mentioned above
Old Oct 6, 2009 | 03:41 PM
AWD Motorsports's Avatar
L19 head studs come in two different lengths 11mm & 12mm.
Are you sure thats accurate.. 11 and 12mm Length??? I think the older DSM uses a different thread pitch and 11mm and the evo uses 12mm diameter or vice versa..
Mike
Old Oct 6, 2009 | 03:46 PM
scorke's Avatar
Just so others are clear, these are not normal ARP Head Studs, these are the 300 dollars for a set suckers...
Scorke
Old Oct 6, 2009 | 04:13 PM
Mike
Its the 4G63 1994 & later uses M11. Anything less is M12.
I'm not sure if the L19 is different. Its not a part they stock on the shelf.
Scorke
si. lol
Old Oct 6, 2009 | 04:17 PM
si. lol
Ok, i knew they were different from Older Gen 4g63.. the length is the same though.. The 11mm and 12mm is diameter..
Mike
Old Oct 6, 2009 | 04:19 PM
CO_VR4's Avatar
The difference between the 11mm and the 12mm studs is not in LENGTH, it's in DIAMETER. The DSM 6-bolt motors used the 12mm studs. The Evo and 2nd gen DSMs use the 11mm studs.
The ARP 11mm L19 studs run about $219.00 from several vendors you can easily find with Google.
Old Oct 6, 2009 | 04:37 PM
Gordian79's Avatar
If my build was as serious that it would require L19s i wouldn't use the 1x1 method.If any oil is the threads you run the chance of cracking the block.
