ARP L19 head studs 1+1... what to TQ???
Old Oct 6, 2009 | 04:40 PM
  #31
CO_VR4's Avatar
^^ Can you explain that? The L19s / H11 tool steel requires oiling in order to protect it from corrosion...
Old Oct 6, 2009 | 04:42 PM
  #32
shunderwunder's Avatar
I'm pretty sure AMS reccomended 95lbs when I asked them a while back.
Old Oct 6, 2009 | 09:20 PM
  #33
ROGERV's Avatar
That's what I did on mine. (AMS L19)
Old Oct 6, 2009 | 10:17 PM
  #34
dcshoeco16's Avatar
When I installed mine I did 85- heat cycled them and retorqued to 95 which I got from MAP/ARP
Old Oct 7, 2009 | 07:13 AM
  #35
Gary@MellonRacing's Avatar
on the traditional arp for the evo , i thought it was 71 of tq ..........
Old Oct 7, 2009 | 07:47 AM
  #36
PATRICK B.'s Avatar
Yes again to be clear this if for the L19 tool steel studs
Old Oct 7, 2009 | 07:50 AM
  #37
TTP Engineering's Avatar
We are using 100-110ft-lbs on L19
Old Nov 20, 2009 | 02:23 PM
  #38
Ev0ikon's Avatar
One of the shop here even TQ them down to 115 Ft/Lb !
Not mine though... Im
Old Nov 21, 2009 | 07:42 AM
  #39
Drifto's Avatar
Are you guys not worried about distorting the block and/or head with that kind of trq? Unless the engine was bored with a trq plate that was torqued down to 90, 95, or 100 I'd say this is not a good idea. I would think the advantage to these over the reg. ARP would be their resistance to stretch under extreme cylinder press and not that they could be tightened more.
Old Nov 23, 2009 | 05:32 AM
  #40
evovin's Avatar
Old Nov 23, 2009 | 06:44 AM
  #41
E85evo8's Avatar
95 ft lbs and call it a day
Old Nov 26, 2009 | 06:41 PM
  #42
mobstrong's Avatar
i have the same question on this topic, but my question is, is there a pattern or step by step procedures of torque, or do i just torque it straight to the recommended torque? anyone actually know the question to this? please help me out, i've been searching around and no answers!
Old Nov 26, 2009 | 07:30 PM
  #43
E85evo8's Avatar
does ARP still call for 30wt. oil to be used on the L19's when installing them? My set didn't come with any arp lube etc...
Old Nov 27, 2009 | 12:16 PM
  #44
slow/ass/rs's Avatar
never tq it down with out the arp lube you wont get a accurate tq reading and the nuts will bind up
Old Nov 27, 2009 | 12:43 PM
  #45
javicracer's Avatar
the normal arp need 80ft/lb with arp lube, and 85 ft/lb if you use 10w30 oil.
