Need help, won't boost over 5 PSI
Old May 10, 2009 | 11:00 AM
gsrboi80's Avatar
Originally Posted by cij911
Your WGA is not connected (the exposed nipple tells all) and you likely have a boost leak....
His WG is connected I can see the line going to the side port. Top port need not be used for MBC applications. No that nipple will not leak boost
Old May 10, 2009 | 11:35 AM
k2boarder3187's Avatar
Check all of your piping once again, make sure there are no rips or holes in any of the couplers.
Old May 10, 2009 | 12:58 PM
K1tt3n5's Avatar
boost leak, check all your vaccum lines. I had a small hole in one of mine and had the same symptoms.
lancerevolution
Sep 13, 2013 09:31 PM
Jesussaves1
Jul 23, 2013 03:58 AM
Spec-OpsMotorsports
Mar 30, 2013 06:08 AM
talontsi97
Jul 18, 2012 12:43 PM
AWD Motorsports
219
Mar 16, 2010 07:23 AM
