need brains 4 boostgauge hookup ...
Old May 11, 2009 | 11:06 AM
mr.turbo's Avatar
Question need brains 4 boostgauge hookup ...
howdie guys,
i promise i did a search but i'm afraid my answer didn't came up very clear ... so,
what about having troubles, because of tapping the vacline of the FPR - wouldn't that cause faulty readings for ECU / FPR ??
wouldn't it be nicer to tap the brakebooster vacline ??
should also be a nice source for vac/pressure readings, aye ?!
anyone already tried, experiences ??
- i found this, look :
http://www.sytyarchives.com/howto/vi...php&dir=gauges
OR is it correct, that evo's ECU/FPR readings do NOT suffer from tapping the FPR vacline, unlike the typhoon (maybe the differnce between MAP and MAF) ??
- i mean it's kinda logical for me, that the FPR sees the vac/boost value after the gauge - there'e a little bit of "delay" that can cause knock or worse IMO ... is that true or nuts ??
(had a gmc typhoon before i got an evo )
THX 4 input, pat.
Old May 11, 2009 | 11:21 AM
EvolNinja's Avatar
I tap mine to the FPR line and it works fine. Not sure about brake boost line you're talking about. Just do as most people do and you should be ok. GL
Old May 11, 2009 | 11:25 AM
Mr. Evo IX's Avatar
Tapped off manifold going to BOV line.
vgknight's Avatar
All my dsms and Evos I have hooked it up to the FPR line... you shouldnt have any problems
Old May 11, 2009 | 12:39 PM
mr.turbo's Avatar
... seems to be an interesting option
please keep going on
Dynotech Tuning
39
Dec 3, 2016 11:04 AM
IamHung
106
Aug 4, 2015 02:13 PM
EvoX4life
Evo X How Tos / Installations
Mar 23, 2015 01:37 PM
evo4life94
Sep 10, 2012 07:41 AM
dac001
Jun 23, 2011 05:37 PM
