Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Help with installing AEM boost gauge
Old Feb 20, 2012 | 08:21 AM
EvoX4life's Avatar
Hello everybody so I went to tackle the install yesterday for my new aem boost gauge. I orginally had an autometer gauge and I just ran the vac line basically from the engine to the cabin which I didn't want tha anymore. I ran the wire the same way though up through the front fender wall but the sensor barely gets inside the engine bay. Any ideas where to secure the sensor at so it doesnt move or any other ideas how I may run the wire. My hands were so cold yesterday I couldn't finish it or else i would of t'd the line and just finished it but I was having second thoughts about the sensor being right there. It looks like it may get wet and I don't know if that is safe.
Thanks
Old Feb 20, 2012 | 11:47 AM
stokEd's Avatar
I ran mine through the fender like (I assume) you're suggesting and mounted the sensor underneath the intake box. I had to add ~6ft of wire to the harness to make it happen; as supplied the harness is relatively short.
Old Feb 20, 2012 | 12:12 PM
EvoX4life's Avatar
That's what i figured I am going to have to do. When I get home from work I'm going to try to run it through the firewall probably and see how that works for me.
Old Feb 20, 2012 | 02:43 PM
gsrdc2's Avatar
i ran it the same way as above and added wire to the harness. i would just solder some wire in there to make it longer cause i found it a pain to try and run through the firewall. good luck
Old Feb 20, 2012 | 04:05 PM
katchup's Avatar
I wouldnt let it be there
Old Feb 20, 2012 | 04:34 PM
EvoX4life's Avatar
I tried today through the firewall and after like 20 mins of twisting and pushing on the grommet I finally got through then I realized there was no way to my hand can fight up there in the cabin to get the hanger and pull it through. Tomorrow I am going to buy additional wire extend it.
I'm not letting it there that's why I asked what did other people do.
Old Feb 21, 2012 | 01:13 PM
EvoX4life's Avatar
Should of looked before i left the house this morning but does anybody know the gauge of the wire for the aem digital boost so i can just go straight to the store after work instead of making an extra pit stop.
Old Feb 21, 2012 | 05:10 PM
kayatic's Avatar
yo bro i have mine ran just like that and have no problems with the sensor being there i just zip tie the sensor to thw corner of the fender ,and ran a longer vacuum hose to the sensor been there for 8,000 mile and no problem,just put some silicon where you bore the grommet to pass the wire tru
Old Mar 23, 2015 | 01:37 PM
Evo82's Avatar
mine came with smaller hose, smaller then the one you need to split with, same with the 3 way connector...what did you use?
EvoX4life
Jul 15, 2013 08:49 PM
Jrod@Buschur
69
Jun 14, 2013 09:27 AM
David Buschur
Apr 8, 2010 08:34 AM
gkmunch
Jun 11, 2008 10:16 AM
BURNALL_4
32
Apr 14, 2008 03:27 PM
