few random questions
Old May 18, 2009 | 06:08 PM
tscompusa2's Avatar
I bought my evo 8 with a 25G setup. I recently removed that setup, and waiting to put my new FP RED in. The 25G wasn't using any coolant or water lines, so I need help finding where these pipes go for when I do the FP RED.
My other question is, is there anyway of being able to detect the type of head studs you're using? Im trying to find out whether the car has ARP studs or not.
Thanks
Old May 23, 2009 | 01:06 AM
Zerokei's Avatar
How was the turbo not using coolant lines.. weird... I'd say just find a picture with a stock turbo set up so you can see where the openings should be. As for the head studs, that's beyond me, GL with that.
Old May 25, 2009 | 10:25 PM
oldevodude's Avatar
You could buy the 8 turbo install kit as it includes 9 lines. There is a how to swap turbo on one of the forums that has pics.
To the Other Poster lot of turbos only have oil for cooling and no coolant lines,
Good Luck
Old May 26, 2009 | 01:27 AM
Wick3d3vo9's Avatar
you'd have to remove the valve cover to see the actual studs
Old May 26, 2009 | 05:54 AM
JakeTheVIII's Avatar
Take off the valve cover, and dab the top of the bolts/studs with paper towel to get the oil off. If they have a hex shaped hole in the top (a spot to insert an allen wrench), they should be arps. The stock head bolts are bolts, not studs. They're bolts with tops. The arp's are studs with a nut that goes down on them. You should be able to tell.
Old May 26, 2009 | 02:56 PM
tscompusa2's Avatar
Good Luck
I bought someones used 8 turbo + manifold, etc etc.. Figured mys well, for a backup turbo setup. I bought the FP kit also, because I want everything to look brand new. Now just waiting on turbo + misc stuff.
Old May 26, 2009 | 02:58 PM
tscompusa2's Avatar
Thanks for this info, I will check this, thanks.
Mauricio Evo IV
11
Oct 31, 2017 12:10 AM
Jesussaves1
Feb 22, 2013 10:56 PM
wrx2evoIX
Oct 20, 2011 05:27 AM
HybridKOOP
97
Aug 29, 2009 02:27 PM
bluebyuevo8
Apr 27, 2005 05:35 PM
