clutch fork!?HELP
Old May 19, 2009 | 11:29 PM
NJ_EveOhVIII's Avatar
Exclamation clutch fork!?HELP
this is the bolt under the freeze plug that holds the fork in. HOW are you people getting this bolt undone with the tranny still attached to the block!? or how do i release the throw out bearing with the tranny still attached to the block. ive tried so much whats the secret!? (R.I.P. middle finger nail)
Old May 20, 2009 | 12:23 AM
boscoyo's Avatar
It would be very difficult to remove that bolt and rod through that hole without separating the transmission from the block. Much easier to release the bearing or remove each pressure plate bolt.
Old May 20, 2009 | 12:30 AM
ive tried the screwdriver in the wedge in every spot in the tranny i can fit a screwdriver. whats the trick to releasing this bad boy?
Old May 20, 2009 | 12:36 AM
boscoyo's Avatar
Advanced Search -> type "throw"-> Title only-> Last post-> Evo IX Engine/Turbo/Drivetrain-> hit "Search"
Would explain how to release the bearing, but I am spent.
Old May 20, 2009 | 12:40 AM
boscoyo's Avatar
There is a picture or two in some of the threads listed that show exactly where the screwdriver belongs. But do you know what the wedge collar looks like?
Old May 20, 2009 | 12:42 AM
yeah i know the thread and trust me i have tried it. i only got it to come out about a tiny little bit isnt the fork keeping it from coming out any more?
Old May 20, 2009 | 12:47 AM
i have a little more space bewteen the wedge and the TOB then in the picture.
Pry toward the block or away?
Old May 20, 2009 | 12:49 AM
boscoyo's Avatar
Ok, I had the same problem. What worked for me was that I switched to a thinner screwdriver and after I worked the driver in between the collar and bearing, I hit the back of the driver with my hand until it would go no more. After that, I twisted as hard as I could and it released.
Old May 20, 2009 | 12:53 AM
boscoyo's Avatar
It does not matter witch way you twist the screwdriver. The bearing will "popping" away from the collar and the collar will stay put.
Old May 20, 2009 | 12:56 AM
is there going to be fireworks and a parade when the TOB releases? how far does this thing come out?
Old May 20, 2009 | 01:09 AM
boscoyo's Avatar
I almost typed " and the celebration started" at the end of my 2nd to last post, but am dragging. It will move as far as wide your screwdriver. After using the smaller driver, I swapped out for the fatter, wider screwdriver and twisted again, to make sure that the bearing had released.
Old May 20, 2009 | 01:23 AM
dtuned's Avatar
I have become a pro at this, and not by design. The threads helped, but also you need to be applying pressure on the fork lever towards the engine side and at the same time twist the screwdriver. If you don't have enough hand strength to push the lever towards the engine, then use a 1/2" drive extension and place it behind the lever and push towards the engine, but be sure that the srewdriver tip is between the wedge collar and the TOB. Once the lever is as far towards the engine as possible... TWIST. It will come off. Let the force work for you... not against you (not referring to any star wars stuff; this is a pull-type clutch, let the pressure plate help you "pull" the wedge collar away from the TOB).
You will feel resistance in the lever and then it will relax big time and will travel all the way to the right. This is when you can do your fireworks because the wedge collar will be released from captivity
Old May 20, 2009 | 01:24 AM
i can push the bearing away from the block now? is that released? its 430 in the morning i give up i hope its now released so i can put the motor in!
Old May 20, 2009 | 01:37 AM
dtuned's Avatar
is the lever all the way to the right? If it is, the TOB and wedge collar are released. If it is stuck in the half way position, then it is still locked in. Just keep trying.
Old May 20, 2009 | 01:41 AM
boscoyo's Avatar
Yes, the lever should be to the far right if you were successful and it should be much easier to move the lever.
