random idle problem
Old May 20, 2009 | 08:50 AM
ev0lution9's Avatar
random idle problem
i got tuned from ivey a few months back and idk with my car its like a random think once in a while stopped at a red light or something my car will studder for a second and go back to normal. also sometimes when going from a gear to neutral my A/F ratio will lean out for a few seconds then go back to normal its a very odd problem any suggestions or ideas?
Old May 20, 2009 | 08:59 AM
yahu's Avatar
Does this happen with your AC on/off the same? I know that when I use AC my idle may occasionally go low to the point where it almost feels like it will stall, but it never does.
I think my A/F ratio does something similar, but can't remember off the top of my head. I know that when coasting (say to a stop light) it goes to nothing for a bit, then when it drops down to the proper idle rpm it does a bit of dancing. I'll watch it next time I drive.
BTW - do you have aftermarket cams? If so, has it always done this or only after cams?
Old May 20, 2009 | 09:04 AM
ev0lution9's Avatar
i never have my a/c on so it just does it no matter what..but it does do that sometimes like its gona stall but then after a few seconds right back to normal like nothing happened...i have stock cams but most of the basic bolt ons like intake exhaust intercooler piping and tuned...when i throw it in neutral from a gear sometimes the idle drops to like 700 or 800 and the A/F ratio leans out then goes back to where it should be
Old May 20, 2009 | 09:17 AM
yahu's Avatar
Hmmm, aftermarket intake? I know sometimes those can play with idle.
Old May 20, 2009 | 11:49 AM
ev0lution9's Avatar
yeah i have the injen intake i figured it wouldnt be an issue since i have a tune but i guess not im just worried about my afr at some points idk if its common or normal
Old May 20, 2009 | 02:10 PM
yahu's Avatar
I think it is normal - as long as it doesn't idle running lean. I know mine bounces around as the motor does its thing.
Old May 20, 2009 | 03:50 PM
AznEvoIX's Avatar
Could be a sign of a failing Throttle Position Sensor. Mine acted that way until I had to replace my TPS.
Old May 20, 2009 | 04:00 PM
Nissan2Evo's Avatar
Sounds like the intake messing with the idle lower load cells.
Old May 20, 2009 | 04:10 PM
max4rw's Avatar
my car does the same, but not at idle, most noticeable in stop and go traffic when moving in gear then when i take out of gear to cost my rpm's will drop almost stalling but never does, I have alike mods. I also thought a tune would solve this problem but it dident so it must be the intake cause I dont remember having this problem until after I installed it, I dont thinck its something to be overly concerned with though
Old May 20, 2009 | 05:50 PM
ev0lution9's Avatar
yeah the only time my idle drops is when goin from a gear to neutral but sometimes the afr will also go lean thats my only concern because otherwise my car runs fine...throttle position sensor idk i only have 12500 miles
Old May 20, 2009 | 06:40 PM
Sean@Iveytune's Avatar
If you can replicate it when you come to the shop we will try to correct it.
Call in!!
Sean
Old May 20, 2009 | 06:46 PM
ev0lution9's Avatar
Call in!!
Sean
yeah i came in about a month ago to explain it to you and you raised my idle a little bit but it seems to do the same thing still its not such a big deal it just gets annoying since it comes at very random times
Old May 20, 2009 | 07:37 PM
leevg's Avatar
I have aftermarket cams, and if i stop at a light with my AC on it stalls...is this normal?
Old May 20, 2009 | 07:41 PM
ok, so how often does this occur? does theAF do anything strange when it stumbles?
Sean
Old May 20, 2009 | 11:53 PM
ev0lution9's Avatar
Sean
yes, its very weird actually when the car randomly stumbles at a stoplight(has never stalled) my afr goes rich as hell then when it happens from going to a gear to neutral the afr goes way lean to the point where the wideband wont even read...after a few seconds it does go back to normal though do you have any ideas sean?
