random idle problem
Old May 21, 2009 | 02:04 PM
  #31
tweakdsm's Avatar
you need to adjust your map/idle for AC/ON.
Originally Posted by leevg
I realize that. I was responding to the same person who is answering your question hoping they would answer mine too.
  #32
ev0lution9's Avatar
my idle is normal at about 900-1000 rpms and i dont VTA im on stock BOV relocated with the injen piping kit
Old May 21, 2009 | 02:05 PM
  #33
UpstateEVOVIII's Avatar
Originally Posted by UpstateEVOVIII
I=also tuned by Ivey
I=also have the random idle 'haunt'
Although it did it stock, also
I attribute it to the 4B11 and it being on if it's 'quirks'
Everyone knows the base maps Mitsu put on the car isn't very good, this is just one of the issues where at idle the load cells bounce around and the car isn't sure what's happening so it starts freaking out. : Shrug :
It doesn't cause any sort of driveability issue, and if I blip the throttle it goes away
I wouldn't worry about it too much unless you're total OCD and just can't take it
QFE since this post got dumped at bottom of the previous page and will probably be overlooked otherwise.
  #34
tweakdsm's Avatar
do you have stock intake? change it and see if that helps, also check your intake make sure everything is connected, and check your vacum lines, maybe you have a small leak between the bov and the intake, check both clamps.
Old May 21, 2009 | 02:10 PM
  #35
kwanza's Avatar
Thank you Kwanza and yahu...
You are welcome. The SAFC II has been brillant for my idle issues with AC on.
Originally Posted by ev0lution9
yeah MY random idle problem not yours make your own thread
I was offering my findings to aid your situation. No need to be hostile. When I got my car tuned I had major idle issues with AC on and off. Car would always stall with AC on, but intermittently with it off. Besides flashing a new idle value to your rom, you can try to adjust the idle screw on your throttlebody.
Old May 21, 2009 | 02:13 PM
  #36
tweakdsm's Avatar
I woulnt recommend touching the screw on the TB. the idle problem with AC on can be adjusted thru Ecuflash, same with idle.
Old May 21, 2009 | 02:15 PM
  #37
ev0lution9's Avatar
no no it wasnt directed towards you i was talking to the other guy who kept chiming in once i got some input on my idle problem
Old May 21, 2009 | 02:41 PM
  #38
yahu's Avatar
Does it actually stall? If so, did it stall at idle too?
Apologies for answering non-OP questions OP, but I answer what I can where I can. Not trying to create drama. IMO I think it is good to have most issues covered in as few threads as possible. It can cut down on the multiple threads for the same issue as well as the "check x thread" comments.
I do see your point though, and apologies for causing any drama.
Old May 21, 2009 | 02:44 PM
  #39
ev0lution9's Avatar
no dont worry about it its all good its jus hard because some of my replies get overlooked when other people try and put their problems in the thread i made ya kno? im just trying to get to the bottom of it
Old May 21, 2009 | 02:48 PM
  #40
thtpel's Avatar
Had the same issue when i had an injen on my car, I tuned the car and it still acted up, when i swaped it out for stock box, it helped right away. then i tried ARC box, and HKS intake as well. Im led to believe that its a hit or miss with an intake, but i know i could be wrong.
Old May 21, 2009 | 02:52 PM
  #41
ev0lution9's Avatar
yeah im coming to the conclusion that thats basically my answer unless someone tells me different...the only thing im worried about is like knock and things like that since my afr goes wacky when it acts up
Old May 21, 2009 | 09:47 PM
  #42
yahu's Avatar
Cool, and I know what you mean. . As tht states, intakes can be tricky toward idle. I know that Buschur stopped selling one of their intake pipes even as it messed with idle (I believe that was the issue, anyway). I am pretty sure he knows how to deal with it via the tune now so he is selling it again.
Old Oct 23, 2009 | 07:35 PM
  #43
harrisonk531616's Avatar
I have the same problem!! this thread came up on my search...so is it because of the injen intake? Should i be concerned about this?
Old Oct 25, 2009 | 09:10 AM
  #44
dastallion951's Avatar
i know the feeling, my car when coming to a stop light and then to idle, car go pig rich like about 10.0 or around there then run lean to about 15-17 and then stabilize out right around 15.0....have 2 02 sensors lying around that i need to install...any insight on anything else that can possibly cause this problem, car has been tune to 27 psi peak on 91 octane built motor....
XinnKoda
Lancer Troubleshooting
Apr 14, 2019 12:27 PM
coreymelton
Jul 19, 2017 11:52 PM
4G63_EVO
Jun 8, 2017 10:02 PM
Sheasta
Dec 23, 2015 07:48 AM
AznDragonV
Jul 3, 2009 09:50 PM
