Dyno numbers WTF?
Like I said the wga is bad and the compression is low. Time to take off some mods and get a new motor via warranty. Yes I said warranty, the guys at Mitsubishi here in town are very cool
Yes justin a new Evo would be number 3 and I just can't downgrade to a 1g after having an Evo. If mitsu will fix my car then fine, if they won't I'll be putting it back to stock and getting Evo #3 cause the third time is the charm...I hope
The car did a stock baseline pull of 225 ft/lbs at 3500 and made the most power of 267. The boost was around 18 psi creeping to 20 by redline (high pressure wg only)
A boost controller was installed on site and the wastegate was turned up. The mivec was adjusted and the car would hit 26-27 psi at 3500 which made 305 ft/lbs of torque and then would go to around 19 psi by redline and only made like 297 hp.
I suggest you take it to a professional to get diagnosed instead of guessing and wondering. Someone with experience will most likely know whats going on in 5-10 minutes time, I'm sure its something stupid thats causing you headaches.
Cheers!
Cheers!
