help plz
Old May 22, 2009 | 10:07 PM
haseeb's Avatar
help plz
my car is not holding boost on any setting on my avcr .it goes over 2 bar on al the 3 off ,A and B settings .checkd all the vacumes on my external wasgate and every where else but they are all fine ,when ever the avcr is on off mode it use to give only 15 psi of boost A setting is set on 1.5 bar and but now its not holding .plz tell me wat else to check
Old May 23, 2009 | 12:43 AM
haseeb's Avatar
any body ?
Old May 23, 2009 | 02:52 AM
dtuned's Avatar
It could be a few things- incorrectly routed vacuum lines, the diaphragm in the wastegate is botched, the wastegate spring may be gunked up or the solenoid for the AVCR is finished.
You did not do any recent work with the AVCR or any of the vacuum lines?
Wastegate actuator vacuum check http://www.dnaelite.com/service_manu...0005800-15.pdf Yes, this is for the stock wastegate, but the principle is the same. Any significant drop is gonna tell you the diaphragm is finished and/or the spring is catching due to oily gunk. Clean it with brake cleaner.
AVCR solenoid check http://www.dnaelite.com/service_manu...0005800-15.pdf Again, this is for the factory set up, and the vacuum check principle is the same.
Good luck
Old May 25, 2009 | 01:33 AM
haseeb's Avatar
thanx
Blitz_b9
Apr 10, 2012 09:26 AM
CrackerJackToy
Aug 11, 2007 06:54 PM
AllBlak
16
May 29, 2006 04:02 PM
1mbrews8
Jan 6, 2005 07:48 PM
expl0d
Jul 18, 2004 09:01 AM
