Boost problem. 10 PSI only.
Old May 25, 2009 | 01:36 PM
dvd_mi's Avatar
When I was driving i noticed a lack of power on my 2005 EVO. The car was not accelerating as it suppose to. No check engine light or anything like that. I looked at my turbo boost gauge and I noticed that it goes only to 10 PSI (before it was around 20). The ECU and turbo are stock. It happened today (suddenly) and it was never like that. Can anyone help me, please?????
Old May 25, 2009 | 01:38 PM
UT_Evo's Avatar
My factory solenoid on my '03 failed and I was boosting right around 10-12 psi all the time, the dealership couldn't figure it out... Wound up putting an MBC in and fixed the problem (and found out what was causing it).
Old May 25, 2009 | 04:07 PM
dvd_mi's Avatar
What is MBC????
Old May 25, 2009 | 04:38 PM
BluEVOIX's Avatar
Originally Posted by dvd_mi
What is MBC????
Manual Boost Controller
Old May 25, 2009 | 05:36 PM
tsidrift1's Avatar
Maybe check your cam position sensor. Mine wasnt completely broke, but it was cracked and you couldnt tell until you looked at it real close. It was causing my car to sputter once it hit like 10lbs.
Old May 25, 2009 | 06:51 PM
dvd_mi's Avatar
So what is the most probable solution???
Old May 25, 2009 | 07:52 PM
project_skyline's Avatar
Check your lines to make sure they didn't come off, sometimes it happens.
Old May 25, 2009 | 07:57 PM
vaboostn33's Avatar
You are only running off your WGA pressure. Go check your boost lines.
Old May 26, 2009 | 05:05 AM
dvd_mi's Avatar
Any suggestions which ones exactly???
Old May 26, 2009 | 05:12 AM
Psquared's Avatar
Look under your intake box. That's where the boost solenoids reside. The lines run from there down to the turbo outlet and to the WGA. They are small, like 10mm black hoses or so. Make sure none are cracked or blown off their fittings. Other than that, check all your intercooler piping for leaks or torn couplers. That's a good beginning..
Old May 26, 2009 | 06:10 PM
dvd_mi's Avatar
Thanks
Old May 27, 2009 | 06:19 AM
Preludepearl417's Avatar
Im having the same problem but im running a AEM tru-boost controller.....at like 7500 its at 10 psi.....wtf?
Old Jul 6, 2009 | 11:07 PM
street dreamin8's Avatar
i had same problem it was the stock boost controler was brokin
Old Jul 12, 2023 | 05:23 PM
Whistlin.evo's Avatar
Did you ever find out what was wrong with it? I'm having the same problem
buckmarley
May 26, 2015 06:42 PM
LetsGo82nd
24
Apr 26, 2011 06:08 PM
2003raptor
27
Mar 19, 2008 08:52 PM
joosdawg
13
Sep 15, 2007 07:18 PM
lynkz
10
Jan 4, 2004 12:10 PM
