OEM spark plugs vs others???
Old May 29, 2009 | 10:58 AM
GgreyEVOIX's Avatar
Well it's been 20k since I last changed the oem plugs for a new set of oem plugs, I've been stock. I just got tuned with a TBE, LICP, UICP, intake, MBC, and 255 fp running 23 psi. Should I just go with another set of OEM plugs or get 1 step colder plugs? What are the right plugs for my mods/boost level? also it might be a silly question but would changing the plugs effect the tune in any way?
Thanks
Old May 29, 2009 | 11:12 AM
GPTourer's Avatar
It shouldn't change the tune, but unless you were experiencing some misfires at high RPMs, I would leave them alone - errr as in replace them with stockers. It wouldn't hurt to try one step colder to see if it smoothes things out on a dyno pull, but something subtle like that won't be felt from the driver seat.
Old May 29, 2009 | 02:45 PM
GgreyEVOIX's Avatar
bump for more opinions
Old May 29, 2009 | 05:45 PM
EatSleepBoost's Avatar
I run NGK BPR8ES 's. they work the best as far as i am concerned. they come pre-gapped and are only about 2 bucks each. i usually buy 8 or 12 when i buy em then change em out every 4-6k miles. They are cheap and it takes 2 seconds to change em. They are the best ones iv used and im gonna stick with em
edit... u have a 9, i have an 8. i believe you are supposed to use different plugs than me
Old May 29, 2009 | 10:11 PM
RyuEvoIX's Avatar
I have always ran factory plugs and I have never had any spark issues even up to 40psi. That's my .02
Old May 30, 2009 | 01:18 AM
Evownz's Avatar
You always want to run as hot a plug as possible with the largest gap possible for the best burn characteristics. Read this.
Old May 30, 2009 | 10:10 AM
G20's Avatar
G20
will you elaborate more about it? any ignition booster, gap... I love to know since with my oem on race gas boosting over 27 psi it started breaking up.
Old May 30, 2009 | 12:25 PM
oldevodude's Avatar
You need to make the gap smaller if you are breaking up or upgrade the ignition to provide hotter spark. I have had to gap down to around 20 to prevent misfire at higher boost on stockish plugs. I have run stock and denso one range colder and both require smaller gaps to prevent breakup above 4k rpm.
good Luck man
fellow SoCal represent
PS I agree the bigger gap is better but that will require ignition upgrade on MY car.
YMMV
barrman
Feb 16, 2015 12:16 PM
BluEVOIX
Dec 24, 2010 04:29 PM
coneman
Dec 22, 2010 10:06 PM
Evo9"Miss Rose"
30
May 17, 2008 08:47 PM
Oracle1
Mar 30, 2008 09:57 PM
