oo Brass shavings in my oil!
Old May 30, 2009 | 12:53 PM
4g63tgt35r's Avatar
has anyone had this happen to there evo?
Old May 30, 2009 | 11:32 PM
barneyb's Avatar
The term for this is "making metal" and it is not a good sign.
Old May 31, 2009 | 11:15 AM
JakeTheVIII's Avatar
That's not good.
Old May 31, 2009 | 11:37 AM
BluEVOIX's Avatar
Are our syncros brass? If so then its probably from the syncros.
Edit**
Is this in the transmission oil or engine oil?
Old May 31, 2009 | 11:41 AM
apagan01's Avatar
yes they are brass
Old May 31, 2009 | 11:44 AM
reactionevo8's Avatar
im going to assume you are reffering to the engine oil and not the trans...if thats the case then metal in the oil is usually followed by a rod knock...get you wallet out and prepare for the worse
Old Jun 1, 2009 | 09:45 AM
C6C6CH3vo's Avatar
If it's alot then the bearing Pb layers are gone and your into the middle of the bearing material - very bad. Block is still good, any more driving will just increas cost.
If there's just trace amount's like 50 specs caught in the oil filter there's a chance the main source could be from the gas pump your using. Fuel has brass contamination from all the pumping required to get to your tank. If this is the case try another station, clean fuel pump, injectors, filters, and oil.
Old Jun 2, 2009 | 12:19 AM
4g63tgt35r's Avatar
hi
Ya its a rod bearing time for a built block to go with my built head it had 70 thousand miles and a lot of it was hard driving 450hp-500hp
Thanks
