what cam's should i get for my 9?
Old Jun 2, 2009 | 08:44 PM
bbyevo8u's Avatar
are the Kelford Hydraulic Camshaft Set 272/272 ok with the stock turbo? or should i go with 264/270's
Old Jun 2, 2009 | 08:52 PM
SPANKED's Avatar
Hmmm Kelford 272s or GSC S2s??? Haven't seen a good comparison of the two.
Old Jun 2, 2009 | 08:55 PM
Blitz's Avatar
Originally Posted by PwrEvo
I have the Cosworth 272's, but I would go with the Kelford 272's because they make more power...
Has this been proven?
Old Jun 2, 2009 | 09:25 PM
bbyevo8u's Avatar
if there are any vendors that can give me a bit of a deal on-- Fidanza 3.2 Clutch Kit and fidanza light weight aluminum flywheel, cobb evo test pipe, apr head studs, Kelford Hydraulic Camshaft 264/270 set with springs and head gasket, please pm me
Old Jun 2, 2009 | 09:26 PM
Clutchdc5's Avatar
the cosworth's werent in the AMS testing, but kelfords were top of the 272 class
Old Jun 2, 2009 | 11:45 PM
Sluggo's Avatar
Those were evo 8 cams, whole different story. Also the kelfords and cosworths are practically identical on paper, so if you're worried about your cossies underperforming against the kelfords, don't sweat it, there is very little difference according to ttp.
Old Jun 3, 2009 | 12:01 AM
Evosick2332's Avatar
Definetly go with the Kelford 272s there are awesome
Old Jun 3, 2009 | 12:04 AM
Domolution's Avatar
Kelfords FTW!!!!!!!
Old Jun 3, 2009 | 07:20 AM
bbyevo8u's Avatar
kelford 272/272 with stock turbo?? is that ok
has the kelford's ever failed or been broken?
just need a lil bit more help before i spend 2k on part
Old Jun 3, 2009 | 07:25 AM
bbyevo8u's Avatar
i know i need springs when upgrading the cam's but do i need retainers? and what brand should i go with?
Old Jun 3, 2009 | 08:06 AM
EvoDom's Avatar
i would stay away from a 4 puck,....you have no idea what your getting into.....goodluck if you go that route.
best cams IMO are Kelford.
in your situation.....Kelford 272's would be nasty.
FP's cams have idling issues.
Old Jun 3, 2009 | 08:15 AM
bbyevo8u's Avatar
thank you very much your post helps alot
what clutch setup do you recommend?
Old Jun 3, 2009 | 08:34 AM
MR Turco's Avatar
I have seen negligible gains with cams on 9s on the stock turbo. Definitely great for upgraded turbos but i would invest the money into something else.
Old Jun 3, 2009 | 08:39 AM
skyblas's Avatar
depends on what kind of cam u want
agressive one or not agressive one
Old Jun 3, 2009 | 08:43 AM
griffeyr's Avatar
Originally Posted by Mike@AwdMotorsports
We have been seeing great gains with the Gsc s2 on FP Red IX's.. They seem to still have great down low and midrange along with on top power..
Mike
hey mike,
how much in gains over the s1's on this setup?
