First EVO8 APEXi Power FC installed
Is the Power FC difficult to install or simply a harness plug and play
Any major gain by getting the D-Jetro version?? D-Jetro will require some installation work to remove and replace the stock MAF sensor only right?
The D-jetro system does allow you greater flexibility with your turbo intake (which is nice) but many people seem to be making plenty of power sucking through the stock MAF system so....
MAF systems allow you a much more precise control over your air/fuel mixture, I find this far more desirable when running closer to the edge. IMO for an all out drag race car, the D-jetro version would probably be better, for road race/street cars I would recommend the standard MAF version.
My experience with MAF on tuned cars, especially tuned Mitsu's is vastly different - MAP sensor is the way to go. It is quite easy to induce MAF overrrun (where the MAF stops counting Karman and just hits its peak) even after porting and a large exhaust. While the MAF is a bit more accurate, it is also a huge restriction and does not allow for the control that a MAP based system does. I could not be more hoenst when I tell you that the VPC, which also converts you to a MAP (but sadly not offered anymore) was the single best mod I ever did to my GVR4.
Originally posted by QAT-R
The Power FC + FC commander + all required sensors comes in a package from MZM for about $1890. This might seem like too much to some but when you consider that you are getting so many engine parameters and even knock sensing display in realtime with out the use of a laptop(which I don't have) then you can start to realize that the Power FC is a bargain when compared to the AEM EMS, autronic etc. The FC commander is so sweet!!!
I think you need to qualify "tunned", the EVO MAF seems to have a pretty wide range, perhaps much better than the earlier DSM's your referring to. So far we are pushing over 300WHP and the MAF sensor is no near it's measurement limit.
It's not just the improved accuracy, it's the greater consistancey that attracts me to the MAF system. I mean let's face it, MAF is certainly not cheaper than speed density, yet every new vehicle I can think of uses it, that should tell you something.
Each type of system has it's pro's and con's, a properly designed relatively mild build up will have more accurate and consistent fuel/ign control with the MAF. If your going wild use the speed density and then carefully monitor and tune your engine parameter's.
Rather than getting into a long drawn out disscusion, both type's will be used and tested in these cars very soon (it's already happening), at various states of tune. Why not let the result's speak for themselves?
tunermt
Jun 16, 2015 10:30 PM
Lancerevo6rs2
Aug 1, 2014 06:51 AM
gavi101
Oct 7, 2013 05:38 PM
robertrinaustin
10
May 27, 2006 11:55 PM
