Clicking Noise from Frontend
Old Jun 11, 2009 | 11:32 AM
kickin wing's Avatar
Question Clicking Noise from Frontend
Over the past week or two I have been hearing a clicking noise from the front drivers side of my car. The only time I can hear it is when I am coming up to a stop sign or to or slowing down under 10 mph. I can have the car in neutral and it will do it. It will do it while I am turning or going strait. it sounds like a card stuck in the spokes of a bike. Any Ideas, Car has 54000 miles on it?
So far I have taken the wheel off and looked to make sure none of the inner fender liner and is touching the tire. pulled the axle nut and applied some anti seize and re-torqued. I am not feeling anything in the wheel or in the pedals
Thanks for your help
Old Jun 11, 2009 | 12:17 PM
mini_evo's Avatar
I can only suggest 2 things....
Take your tire back off and check for nails/rocks stuck in the tread. And while you have the tire off...... Check the half shaft for play! Grab hold of it and shake it. (in, out, up, down) Other than that G/L
Old Jun 11, 2009 | 01:12 PM
its not a rock I will check the CV Shaft tonight. I was thinking it was a wheel bearing but it does not howl or change tone or pitch when making turns
Old Jun 11, 2009 | 03:03 PM
Axles are tight
Old Jun 11, 2009 | 04:01 PM
Evo8Emperor's Avatar
boost control solenoid.
Old Jun 11, 2009 | 04:46 PM
its not hooked up
Old Oct 10, 2009 | 02:48 PM
Master Evo8's Avatar
Did you find out what was causing it? I have the same problem.
Old Sep 17, 2012 | 02:32 AM
wasabisnooter's Avatar
I know this thread is old but i'm having same issues. Any insights?
Old Sep 17, 2012 | 01:25 PM
KOOLER's Avatar
Ssdd
Old Sep 17, 2012 | 01:52 PM
Huh?
Old Dec 13, 2013 | 06:46 AM
st_evo's Avatar
Anyone have any idea what the issue is? Several threads that just seem to die off. I'm having this issue and can't track it down.
Old Dec 13, 2013 | 01:51 PM
barneyb's Avatar
When threads die off like this with no comeback I suspect it indeed was a rock in the tread. Who wants to admit to that?
lilmac789
Lancer Engine Management / Tuning Forums
Jan 20, 2011 09:56 PM
evane
Aug 29, 2008 11:32 AM
Punisherofall
Oct 10, 2007 12:06 PM
Bigl4201
Aug 14, 2007 09:58 AM
pumpdog720
Aug 22, 2004 08:35 AM
