What would you do????
Old Jun 12, 2009 | 03:50 AM
Yamahar1's Avatar
Here's the deal....I can either rebuild my bottom end (car has 88,000 miles on it) with the following...
Wiseco pistons with rings 9:0:1 compression
Eagle rods
ACL race bearings...rod & main standard size
ARP main studs
OEM gasket kits
Or buy.....
EXEDY TWIN DISK HEAVY DUTY MM022HD
GSC Beehive Spring & Retainer Kits
OEM headgasket
Old Jun 12, 2009 | 04:05 AM
mini_evo's Avatar
I would do the internals first. Get all the BIG work out of the way first.
But then again, what is your final goal with the car? Is it big turbo and cams, or just minor bolt ons!?
Old Jun 12, 2009 | 04:39 AM
Yamahar1's Avatar
I am looking for 500-600 HP. Here is a list of mods.....
Buschur double pumper
BC 272 cams
ETS HTA35r turbo kit w/44mm wg
Injen air intake
bigger intercooler
3" TBE
1200cc injectors
stock 9 BOV
gates racing timing belt
E-85 ----English racing tune
stock block------------------(88,000 miles)
stock ecu
Ingalls engine damper
BLOX Racing Front Engine Roll Stopper
Greddy catch can
Shep Street & strip transmission
Shep stage 3 transfer case
ACT 6 puck sprung
ACT streetlite flywheel
Old Jun 12, 2009 | 04:54 AM
yahu's Avatar
personally I would go with option #1. Are you on stock clutch/tranny? If so that is good to know but you might end up having to go with option #2 as you continue with your mods and option #1.
Old Jun 12, 2009 | 05:08 AM
Yamahar1's Avatar
I have the Shep street & strip W/
EVO 9 1st gear ratio
REM ISF process gearset with rails and hub/sleeves
REM ISF sleeves
REM ISF hub/sleeves and shifter rails
ACT 6 puck sprung---MB7-XTG6
ACT streetlite flywheel----600205
Old Jun 12, 2009 | 05:19 AM
yahu's Avatar
I'd definitely go option #1 then.
Old Jun 12, 2009 | 05:34 AM
grillpt's Avatar
With your mod list I would def go with option #1.
Old Jun 12, 2009 | 05:43 AM
JakeTheVIII's Avatar
Option 1 easy.
Old Jun 12, 2009 | 06:01 AM
Yamahar1's Avatar
Thanks Guys!
Old Jun 12, 2009 | 11:38 AM
FX11's Avatar
Wow your car is going to be a beast once your done! But idk how well that Act 6puck will last with all that power
Old Jun 12, 2009 | 11:53 AM
ETS Michael's Avatar
Option 1 doesn't sound bad =)
Thanks,
Michael
Old Jun 13, 2009 | 05:14 PM
Yamahar1's Avatar
Thanks I hope so
Old Jun 13, 2009 | 05:15 PM
Yamahar1's Avatar
option 1 it is....Motor is coming out tomorrow. Thanks everyone
Old Jun 14, 2009 | 06:14 AM
grillpt's Avatar
take pics and keep posting...
Old Jun 14, 2009 | 12:05 PM
dambikeracer's Avatar
BC 272 cams
Injen air intake
bigger intercooler
3" TBE
1200cc injectors
stock 9 BOV
stock ecu
Greddy catch can
ACT 6 puck sprung
If all this is already done, I would built the motor and turn up the boost!
