oil leaks
Old Jun 27, 2009 | 11:49 AM
EvoAlex48's Avatar
Question....If there is way too much oil in the car...would that cause oil to leak out of the oil pan gasket....if it would...then thats my oil leak. oil on my dipstick is like 2in above the 2nd notch
Old Jun 27, 2009 | 12:02 PM
apagan01's Avatar
i noticed in your pictures that the bolts for the oil pan looked like they were stripped the heads of the bolts.
was the pan removed ??
was the tranny every removed or the TC ?
give some history on before this happend
Old Jun 27, 2009 | 12:07 PM
EvoAlex48's Avatar
well..i think i may have found the cause of the leak....someone give insight, so i checked underneath my car, oil is dripping out of the oil pan seal...everytime i check the dipstick the oil is hovering like 2 in above the 2nd notch....this troubled me, so i whipped out the owners manual....oh the f'in oil is way to high, its supopsed to be between those 2 damn notches, so im guess thats why there is oil comin outta my oil pan, anyone agree/ disagree???
Old Jun 27, 2009 | 12:10 PM
apagan01's Avatar
if the oil level is to high, it would not come out of the oil pan gasket unless you blew it.
oil doesnt just come out of the pan the pan is completly sealed,,, it would mess up the engine before it did that.
get under there with some degreaser and wash everything and watch for the leak
Old Jun 27, 2009 | 12:11 PM
EvoAlex48's Avatar
hmmm, Theres oil coming out all around the oil pan though....its like it is dripping out the oil pan and off of everything else, i ran my finger along the seal on the oil pan and oil was dripping down my hand
Old Jun 27, 2009 | 12:13 PM
EvoAlex48's Avatar
clutch had to be repeatedly worked on, tranny came off a few times, new motor was installed recently, the last time my car was worked on and it didnt leak, was right before i had my new pressure plate installed....ever since then it has been leaking....
Old Jun 27, 2009 | 12:17 PM
apagan01's Avatar
well then is very posible that it is leaking thrue the pan gasket.
like i said before, the pictures you posted by looking at them it seems like the head of the bolts were messed up ( stripped )
you can go ahead and torque the pan, the bolts are 10MM socket, here on evom they have the torque specs for that, make sure all the bolts are tight,,, and when you torque the pan i would do them in a criss cross pattern,, this will keep the pan in a flat plane and not warpped.
GL
Old Jun 27, 2009 | 12:22 PM
EvoAlex48's Avatar
if the oil is too full...wont that cause too much pressure and thus blow the gasket? the bolts arent stripped, the sealant around them made it look like it was stripped
Old Jun 27, 2009 | 12:23 PM
EvoAlex48's Avatar
how hard is it to change the oil pan gasket? and can you get it at pep boys/ autozone or what?
Old Jun 27, 2009 | 12:31 PM
EvoAlex48's Avatar
and i am deprived i only have socket wrenches =[
Old Jun 27, 2009 | 12:33 PM
apagan01's Avatar
i dont think you can get it at those places, get you an OEM and some high temp RTV.
it is very simple to change, make sure thats your problem before you go and change that.
like i said before, get your self some degreaser, and clean your car underneath, this will help you reveal where the leak is comming from, right now there is to much junk up in there to even know if its comming from the pan
Old Jun 27, 2009 | 12:39 PM
EvoAlex48's Avatar
oil is def comin from the oil pan...
Old Jun 27, 2009 | 12:46 PM
apagan01's Avatar
then swap that gasket
good luck brother
Old Jun 27, 2009 | 12:49 PM
def1's Avatar
does it leak when the car isnt even running? If so then it is most likely the oil pan. I used toyota silicon gasket to replace mine but its pretty pricey. You can buy some silicone from pep boys or autozone if you like.
If it only leaks when its running I would check other things. Check the timing tensioner bolts, the oil return line from the turbo. The oil cooler lines. and the valve cover gasket.
Old Jun 27, 2009 | 12:50 PM
EvoAlex48's Avatar
dealership just said that there is no gasket for 03 evo oil pans...so i just use some rtv correct?
