wiped out maf and now car doesnt run right until wot????
Old Jun 19, 2009 | 12:36 PM
murderedevo256's Avatar
All i did was clean out my intake and the maf there was a little grime in there so ALL i did was wipe it with a rag. Now my car doesnt idle right or run right until like 4 grand when the wastegate opens. any clues? Its obviously hooked up correctly just a few clamps and its plugged back in fine
MOD can you move to general section please wrong section!!!
Old Jun 19, 2009 | 12:38 PM
eve-slow's Avatar
Did your MAS get unplugged?
Old Jun 19, 2009 | 12:42 PM
Macaroni's Avatar
Just switch to speed density and get rid of that deathbox!
Old Jun 19, 2009 | 12:51 PM
MR Turco's Avatar
you physically touched the maf circuits? You probably screwed it up.
Old Jun 19, 2009 | 12:53 PM
I just wiped out the inside where the u shaped wire hangs down. if that is touched could that effect it? Its plugged in to
Old Jun 19, 2009 | 01:08 PM
MR Turco's Avatar
yes it could. Where are you located?
Old Jun 19, 2009 | 03:40 PM
in pennsylvania
Old Jun 19, 2009 | 03:48 PM
1320 Engineering's Avatar
i guess you could try to clean off anything you might have gotten on there with some good maf cleaner. otherwise it might be time to pick up a new one
Old Jun 19, 2009 | 03:52 PM
Kings Fan's Avatar
Spray it with some MAF cleaner and see if it works, check the wires for open/short circuits. Make sure the maf housing isnt rubbing/bumping into anything else in the engine.
Old Jun 19, 2009 | 04:00 PM
toverton30's Avatar
man i hope u fix it G/L keep me posteds o i dont do this
Old Jun 19, 2009 | 04:51 PM
Evoryder's Avatar
how does the car run with the maf plug disconnected? Did you use CRC maf sensor cleaner on the maf or throttle body cleaner?
Old Jun 19, 2009 | 06:26 PM
I used a cleaner and it did nothing still. Im getting the codes Po113 and P0107 so idk why I wasnt getting those at all before then now getting them after cleaning the maf? weird to me but thats all I have so far
Old Jun 19, 2009 | 07:09 PM
anything?
Old Jun 19, 2009 | 07:51 PM
Evoryder's Avatar
what cleaner? sounds like you screwed up your maf.
