ac problems!
Old Jun 19, 2009 | 04:08 PM
idriveanevo's Avatar
ac problems!
I pulled the engine from my car and had to break open the ac, so I recently had it recharged and it was working great until after got the car tuned. When I first turn the ac on, it will blow cold for less than a minute then start to blow warm air.... at idle it seems to work fine but it does not work at all on the highway. the compressor seems to be activating because it idles like crap with the ac on and at times afr goes way lean to about 17 then id idles back up. today i took it to the shop and they put the ac gauges on it and the high side would shoot way up to 450+ when the car would bog down from crappy idle but when it idles smooth, it would be around 250psi... any ideas what could be causing this?
Old Jun 19, 2009 | 04:11 PM
EvoDan2004's Avatar
ight have a small leak. it may need a recharge. check for leaks
Old Jun 19, 2009 | 04:17 PM
wevo1985's Avatar
sounds like you have mosture in the system. itll freeze and cause the high pressures. you should replace the can looking thing by the condensor in the front of the car. its called a reciever dryer.
Old Jun 19, 2009 | 04:18 PM
i just had it checked today and it was fine. it even went way up to 500 psi when the car stalled out! we even let some out....
Old Jun 19, 2009 | 04:20 PM
wevo1985's Avatar
how long did you have the lines unhooked?
Old Jun 19, 2009 | 04:22 PM
about 2 or 3 months...... i had all the lines covered but i guess moisture could have still goten in there... we pulled a vacuum on it before it was recharged
Old Jun 19, 2009 | 04:27 PM
wevo1985's Avatar
well the dryer is full of desiccant so if the lines are open than itll just obsorb and hold. so that would be where the mosture is coming from. and the mosture will freeze causing clog and a high pressure. also causing the ac to not work correctly.
Old Jun 19, 2009 | 04:30 PM
EvoDan2004's Avatar
i have a full evo9 a/c system for sale if needed. pm me. we can talk price.
Old Jun 19, 2009 | 04:38 PM
would there be any way to see if the dryer is freezing up?
Old Jun 19, 2009 | 04:44 PM
toverton30's Avatar
its sounds like its freezing over
Old Jun 19, 2009 | 04:45 PM
what all should be replaced? the dryer and is there anything else that should be replaced?
Old Jun 19, 2009 | 04:48 PM
meckert's Avatar
drier should do it...thats a given
Old Jun 19, 2009 | 04:52 PM
what about an orfice tube(spelling?) or an expansion valve? theres nothing else like that on the evos?
TouringBubble
Oct 10, 2025 11:11 AM
CharliEvo8
Jan 5, 2025 10:14 AM
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Spythere
Jul 5, 2016 03:09 AM
lan_evo_mr9
Jun 23, 2008 07:28 PM
