Is this HP gain for real?!?
Old Oct 6, 2003 | 02:29 PM
EVOFREAK's Avatar
Brainstorm has an exhaust that is the turbo back for 1250$. I says that it get 40hp and 50ft/lb . Is this true? The website has the dyno chart but I am still wondering if it is true.
This is their website: www.turboperformance.net/bsp/
Go to exhaust and then click EVO 8 and then click turbo back.
Old Oct 6, 2003 | 02:40 PM
Guru_Del's Avatar
looking at the dyno i only see a 20 hp increase 236-256
Old Oct 6, 2003 | 02:41 PM
bobaab's Avatar
that's what i see too
Old Oct 6, 2003 | 02:44 PM
SilverEvo8owner's Avatar
+1
Old Oct 6, 2003 | 02:47 PM
Fireball's Avatar
They're claiming a 40hp-50ft/lbs w/o the cat. The dyno graph is leaving the stock cat in there.
Old Oct 6, 2003 | 03:43 PM
ru4real's Avatar
They didn't claim 40hp and 50 lb-ft increases for peak numbers. If you look at the dyno chart, you can see a maximum gain of 40hp between 6200 and 6400 rpm, and a maximum gain of 50 lb-ft at 2900 rpm.
Peak numbers are easy to throw around, but the way the exhaust increases usable area under the curves is what is important.
Old Oct 6, 2003 | 04:07 PM
EVOFREAK's Avatar
I see thanks for clearing that up.
