Clutch pedal stuck!!!
Subscribe
Jun 20, 2009 | 08:44 PM
So went for a drive this evening, and was shifting from 1st to 2nd let off the clutch in 2nd and it was stuck to the floor... I pulled it out with my foot, and now the clutch is stuck! It wont budge at all...
Ideas?
Reply 0
Jun 20, 2009 | 08:45 PM
Try bleeding the clutch...
Reply 0
Jun 20, 2009 | 08:47 PM
Try bleeding the clutch. Do you see any fluid anywhere? How's the level?
Reply 0
Jun 20, 2009 | 08:52 PM
I do not see any fluid, but it is dark out. I will check the fluid level.
Reply 0
Jun 20, 2009 | 08:54 PM
What would cause this to happen?
Reply 0
Jun 20, 2009 | 09:06 PM
Any number of reasons at this point. Possibly a bad slave cylinder, possibly a bad or blown out seal somewhere has let in air on a line or otherwise, mechanical failure in the clutch, the list goes on.
Reply 0
Jun 20, 2009 | 09:10 PM
The fluid level is fine.. I dont see any fluid. Some people have told me it is a ring in the clutch that breaks sometime. I am not exactly sure what this "ring" is. ?
Reply 0
Jun 20, 2009 | 09:12 PM
Subscribed. GL, I am def curious.
Reply 0
Jun 20, 2009 | 09:14 PM
First things first attempt a proper bleeding procedure on the clutch. In my short time on these forums I have heard of a dead pedal fixed by a good bleed.
Reply 0
Jun 20, 2009 | 09:17 PM
Quote: First things first attempt a proper bleeding procedure on the clutch. In my short time on these forums I have heard of a dead pedal fixed by a good bleed.
This is what i will do then. Unfortunately i do not have the spot or tools to do it at my place, so it will have to be towed to the shop.
Reply 0
Subscribe
