Anyone have problems with low idle stalls?
I have an o4 evo with the works 340 package and a white turbo and a few times when it's hot out it has stalled(with a/c on). The idle will dip a bit and the engine dies but starts right back up. Does anyone else ever get this problem? I notice that if I let it idle and it is not in gear it keeps the revs up.
Mine has sallee two times I had it about 3-4weeks sometimes I think it will stall cause it will go so low in rpm like if I am in first and take it out of first to get into a parking spot my boy said it could be the bov I got the car with an aftermarket bov
I understand that the A/C takes up a bit of vaccuum. I have an evo ocho and when i kick my A/C on it idles at 600-500rpm. Normal idle is around 800rpm for me.
I would consult WORKS or your neighborhood tuner, see what their .02 cents are on the issue.
Are you running VTA for your BOV??? If so recirculate and problem solved. There is a couple of threads out there for this issue.
Evo4walshy
Feb 10, 2017 06:47 AM
